Hi does anyone know where the water pump is located on the z20net? Also is it aux or chain driven? Thanks
Chain driven mate, airbox end of the engine.
How long do you think a garage would take to do it?
There's no point doing the waterpump withought doing the chain so factor in the extra cost.
what sort of cost am i looking at?
It's driven by the balancer shaft chain, so first the timing chain has to come off, then you get access to the balancer shaft chain. It's not meant to be a consumable item, so rarely goes wrong - what's leading you to believe yours is knackered?
It's over heating. The thermostat, temp sensor and coolant have all been changed. The heads defo not gone. Not losing any water and no sludge in oil
Then I guess that the water pump is indeed your next bet. If the chains haven't been changed, this is the opportunity to do them at the same time.
Maptun Tuned 2.0T Estate - click HERE for mods list.Brentwood 2012: Winner, Saturday Show. Hull 2012: Winner, Best Estate. Hull 2013: Winner, Best Estate & Runner Up, Best I.C.E
