Thread: Fitting cd70 navi, into a 05 full canbus
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Fitting cd70 navi, into a 05 full canbus
    Is this a straight plug and play the car is full canbus,,,,will it need tech2 or anything? Cheers
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Plug and play.
    If it came from a car with a different aircon type than yours you can get this changed later on.
    Sep 2010
    Leeds
    Cheers pal. Just got to find one now! It has to be colour screen one The prefacelift one will be better but does the facelift one still fit as vents are slightly rounded on edges.
    Sep 2010
    Leeds
    Im on verge of buying one from a 07 plate cdti, mine is a petrol, does this matter? And what if there is no car pass code for it? And lastly there is no aerial so will it still work apart from satnav? I just want a colour screen anyway. I dont want to have to divorce/marry/tech2 etc... Cheers please help before i waste money! Lol
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    239 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    You won't need the pass code if the units are already paired together.
    You can get a fakra GPS from the likes of ebay which will sit in the tray for the centre dash speaker (just lift the tray out and drop in the satnav antenna and plug it into the CD70 below).
    I'm not sure if you will need the security code from the donor car if anything ever needs to be re-programmed however (like TPMS) so am sorry I can't give you the final final answer, but as far as a working satnav, it should be ok.
    The dash trims are different on a facelift from a preface which has "squarer" edges to the trims. You could probably live with the finish or look out for the pre-face trims however there was only a short time period when the car went from halfcan to fullcan before it finally became a facelift, so there aren't too many pre-face trims around that will suit the CD70, BUT they are out there.
    The problem is that most of the trims are sold with the SatNav displays and HeadUnits, so don't hold your breath.
    HTH
    Woody
    Sep 2010
    Leeds
    Cool thanks woody
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 50k
    Dam!! I just buchered a CID pre face surround to fit my cd70!! Arrhh a nice little swap would have been in order lol just done it a month or two ago, bad timming lol but in answer to ure question as mine I dont have the pass code, I can get it but at present I dont need it, but yea it will work if its the cd70 and CID are a pair, but urw fuel type is different so ure mpg will be off but u dont need a pass code to change the code index to a petrol code, I dont think anyway, plasma would be able to sort u with a security code, and robsey would help u with the code index, ino it sounds complicated but its not really.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 50k
    If u do get one with a facelift surround I would be intrested in buying it from u as the butchered one looks a bit naff, ill keep my eye out for a pre face.
    May 2012
    239 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by rozzer2006 View Post
  1. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  2. For Sale: Cd70 navi colour satnav full set
    By pszczo in forum Parts for sale
    Last Post: 17th March 2013, 20:44
  3. fitting aftermarket rear parking sensors to full canbus, any issues?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2012, 10:41
vectra c facelift fitting cd70 navi
CD 70 navi can bus
https:www.vectra-c.comforumshowthread.php182198-Fitting-cd70-navi-into-a-05-full-canbus
