Thread: P0420, p0301, p0304
    Aug 2011
    Bristol
    Default P0420, p0301, p0304
    Thought I would start from scratch.
    Got code reader today and plug in to find the above.
    301 and 304 misfire in 1 and 4
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    What is the cat 1?
    Is that my cat kaput or is this my 02 sensor playing up?
    Is this what is causing the misfire or is this in addition to the misfire or is the because of the misfire?
    Live data and freeze data I can put up too if it would help.
    So far
    Ignition coil changed
    Plugs changed
    Fuel Pump changed
    FPR changed.
    This has only been occuring since a water pump change of which the only thing removed was exhaust manifold
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Have you cleared the codes and re read them?
    Aug 2011
    Bristol
    not since changing fpr.
    Only just got this reader so just getting used to what I need to do
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Clear and re read, then see what the reader comes up with. Id have said the cat code is possibly a follow on from the misfire codes, one affecting the other IYKWIM?
    Aug 2011
    Bristol
    Cleared codes and now nothing showing. No difference as misfire will still occur.
    Freeze data gives me detail on misfire in cylinder 1
    DTCFRZF P0301
    Fuelsys1 CL
    Fuelsys2 N/A
    LOAD_PCT (%) 65.5
    ETC (F) 199
    SHRTFT1 (%) -2.3
    SHRFT3 (%) -100
    LONGFT1(%) -5.5
    LONGFT3(%) -100
    MAP(inHg) 23.3
    RPM(/min) 3434
    VSS(mph) 46
    FRP(PSI) 1337.2
    Although I don't understand any of that it seems all sensors and fuel seem fine at misfire.
    I do believe CAT is fine and just threw 420 up because of misfire.
    Readings on idle if anyone understands these details
    Idle
    DTC_CNT 0
    Fuelsys1 CL
    Fuelsys2 N/A
    LOAD_PCT (%) 12.2
    ETC (F) 167
    SHRTFT! (%) 2.3
    SHRFT3 (%) -100
    LONGFT1(%) -2.3
    LONGFT3(%) -100
    MAP(inHg) 6.8-7.1
    RPM(/min) 748-760
    VSS(mph) 0
    SPARKADV(0) 29
    IAT(F) 52
    MAF(lb/min) 0.287-0.295
    TP(%) 2.7
    02SLOC B1S12--B2S----02B1S2(V) 0.410-0.425
    SHRTFTB1S2(%) -100
    OBDSUP EOBD
    MIL_DIST(MILE) 0
    FRP(PSI) 690.7-746.9
    EQ_RATB1S1 0.996-1.009
    02B1S1(V) 1.498-1.532
    EQ_RAT11 0.996-1.008
    02S11(mA) -0.078-0.023
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    If you've got a misfire then your not burning fuel properly
  1. P0304 help
    By pogvec in forum Engine & Drivetrain
    Last Post: 16th February 2012, 14:36
  2. p0420
    By jimbo1987 in forum Engine & Drivetrain
    Last Post: 1st February 2012, 22:56
  3. P0301 & P0304 misfire
    By tridley in forum Engine & Drivetrain
    Last Post: 27th September 2010, 00:06
  4. EML - Vec B 2.2 Sri 150 - P0420
    Last Post: 14th September 2010, 13:06
  5. P0420 Fault Code
    By Hyperhart in forum Engine & Drivetrain
    Last Post: 19th February 2010, 19:34
