Thread: Hi New member and Vectra C owner, need some advice.
    Feb 2013
    medway
    Engine : 1.9 CDTi
    Default Hi New member and Vectra C owner, need some advice.
    Hi
    I have recently purchased an 06 vectra SRi CDTI 150 with the Z19DTH engine. I am very happy with the purchase and its a massive upgrade in pretty much every way coming from a 1998 ford escort!
    However, i do seem to have a couple of small issues with it. Firstly, it appears my thermostat is shot and stuck open as the temp gauge rarely goes above 80'c and when it does its whilst climbing a steep gradient. Cruising on the motorways etc brings the temp down to zero where it pretty much stays throughout most my journeys. To get any hot air out of my blowers, i need the heater on pretty much full hot!
    I have had a look at the thermostat housing on the engine, It does not look like too much of a problem to change, perhaps a little bit tight? I have quite a lot of experience with engines & mechanics etc so im not new to any of this, however, if there is a 'How too' guide or similar for me to go over first, i would be very grateful if someone could point me toward it?
    My second issue i feel is going to be slightly more of a problem... I have the CD70 colour NAVI stereo, its all up and running with no issues howeverwhen i purchased this car, i was not given the car's manual containing the code key for the stereo. How can i obtain this code? and if i disconnect the battery or pop the fuse to the stereo by accident, would this cause the stereo to require the code to be input?
    Many Thanks for your help
    Ryan
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    If you have the car pass you can get the code from the dealer.
    Feb 2013
    medway
    Engine : 1.9 CDTi
    Car pass?
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    http://www.vectra-c.com/forum/showth...150-Thermostat
    heres the thermostat how to mate its pretty straight forward i used it to do mine ,
    if youve got the car pass your code should be on there,also
    welcome to the site
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You do not need a code for the stereo, its not an old Ford escort lol
    The HU is matched to the GID and to the car using tech 2 and this is not affected when you disconnect the battery.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by merikiito View Post
    You would if it was a half can vec/sig.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by GazCDTI150 View Post
    True but his is a facelift 06 so he's in the clear
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Yes but I'm clearing it up incase someone gets the wrong information.
    Feb 2013
    medway
    Engine : 1.9 CDTi
    Thanks for the replies here everyone. I called vauxhall and they quoted me £44 for the thermostat so i shall be getting one asap.
    With regard to the stereo again, you say its interfaced with the cars Cam-bus so therefore i shall not require any keycode; therefore i can safely remove the stereo completely and re-install it without any issues? I ask as i would like to fit an AUX-In to the stereo, i have seen a few pictures on google of the rear of the cd70 with pins for an AUX input, so i hope i will find the same on the back of mine? Can anyone confirm this? Perhaps there is a how too, so i know which pin is R+/L+/- ?
    Also lastly, If i was to remove the battery from the remote-locking keyfob for any length of time, would the keyfob require re-programming?
    Many thanks
  1. Longtime forum member, now Vectra C owner too!
    By Barchettaman in forum Introduce yourself.
    Last Post: 29th January 2013, 23:27
  2. Big hello from new Vectra owner and forum member
    By Shawzy in forum Introduce yourself.
    Last Post: 12th June 2012, 12:48
  3. New member, first time Vectra owner
    By MultiDropper in forum Introduce yourself.
    Last Post: 4th August 2009, 14:36
  4. Hi All, New Signum Owner & New Vectra-C Member
    By dennis_signum in forum Introduce yourself.
    Last Post: 12th January 2008, 02:12
  5. New Vectra C Owner/Member
    By chrisschild in forum Introduce yourself.
    Last Post: 31st May 2006, 10:05
