Results 1 to 3 of 3
Thread: Tappets and cams??
    Dec 2012
    Birmingham
    Default Tappets and cams??
    Hi after changing valves, engine gaskets and cam/balance chains on z22se I started the car and tappets seemed noisier than before. When the engine warms up there was also a squeak.
    I took the cam cover off and it seems there is no oil feeding the cams. Could there be a blockage and where is best to start looking?
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    I always remember a job i did on a clio where somebody had put the head gasket on the wrong thus blocking the oil pickup. The gasket looked very similar fitted both ways only difference was the oil feed holes. Im not sure if thats possible on the z22 as ive never stripped one down, but may be worth considering
    Dec 2012
    Birmingham
    Thinking about it though there was a black grommet with a pin hole in the centre that came off my head when I took it off but there wasn't a new 1 in the gasket kit so fitted it back (which was a pain). Maybe that is blocked...
  1. cams
    By HARRY SRI in forum Diesel Engine related
    Last Post: 17th April 2012, 15:55
  2. z20net tappets
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 21:28
  3. 3.2 v6 cams???
    By jackharrison12000 in forum Petrol Engine related
    Last Post: 25th May 2011, 17:15
  4. Cams...
    By Danwells72 in forum Diesel Engine related
    Last Post: 31st October 2010, 03:24
  5. Cams
    Last Post: 11th January 2010, 20:16
