Results 1 to 10 of 18
Thread: Signum handbrake issue
    Regular Member Desolation91's Avatar
    Jan 2013
    Chesterfield
    Trim : Elite, Tan leather
    Engine : 1.9 CDTI
    Mileage : 106000
    Default Signum handbrake issue
    Ok so I'm in the process off getting a new left side rear caliper but the other still works since rich unseized it.
    I have found the handbrake cable guide that shows the reset part of the handbrake but it doesn't show how to get to it...
    Is there any bother way to stiffen the handbrake? As it roles back on hills unless you pull it right to the top..
    Also can you replace the plastic handbrake cover?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    I think you just keep pumping the brakes and cranking the handbrake lever. It should tighten up.
    Dec 2012
    Midlands
    First day I put my Signum on my driveway I had to go a retrieve it from the middle of the street 10 mins later as it had crept backwards. I have to pull the level as high as I can pull it and leave it in gear to get it to stay put. Apparently there was a recall on poor hand brake but my local dealer checked the records and told me mine has already had it :-/
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    Oh really?? I'll give them a call. Thanks for that
    Dec 2012
    Midlands
    Quote Originally Posted by Desolation91 View Post
    Yeah -> http://www.warrantyguide.co.uk/vehic...-signum-recall
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    Looks like a few things I could ask about when I ring.
    Vauxhall
    Search results (1–3 of 3) New search
    Recall: No. 1 of 3
    Recall Ref: R/2005/166
    Exact Model: Signum and Vectra
    Description: Rear axle hub may not be to specification
    VIN: SIGNUM - 00000006*102*5432 to 00000006*103*6596, VECTRA - 00000006*102*5432 to 00000006*103*6596
    Build Date:
    Numbers: 783
    Defect: The hardening process applied to the rear wheel bearing inner ring may be incorrect. There is a possibility that a rumbling noise may become apparent, which if not checked could in extreme circumstances result in the detachment of the hub and severely impaired road holding/handling.
    Action: Recall the vehicles that are likely to be affected and check the date stamp on the rear wheel hubs. Where necessary, replace the hub bearing assembly.
    Launch Date: 17 December 2005
    Recall: No. 2 of 3
    Recall Ref: R/2008/014
    Exact Model: Vectra C & Signum
    Description: HANDBRAKE MAY PARTIALLY RELEASE
    VIN: 21017709 to 71106592
    Build Date: 1/1/02 to 31 Dec 07
    Numbers: 236284
    Defect: Following a small number of complaints of Vauxhall Vectra and Signum vehicles rolling away due to allegedly defective handbrakes. Vauxhall engineers in conjunction with consultants and other bodies, have conducted rigorous testing and found that provided the handbrake is applied correctly without depressing the release button, the handbrake is perfectly safe.
    Action: In line with it's priority of continuous improvement, recalled vehicles will be fitted with a modified handbrake mechanism to reduce the possibility of a partial release.
    Launch Date: 07 April 2008
    Recall: No. 3 of 3
    Recall Ref: R/2004/148
    Exact Model:
    Description: Rear exhaust pipe may move backwards slipping off the front pipe
    VIN: 00000000041019521 to 00000000041133883, and 00000000041013500 to 00000000041133906
    Build Date:
    Numbers: 7572
    Defect: The possibility exists that the rear exhaust pipe can move backwards and slip off the front pipe. With the possibility that under body components may become damaged.
    Action: Recall affected vehicles and check likely to be affected under body areas, and install a new exhaust clamp.
    Launch Date: 05 November 2004
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    well i have rang vx and apparently its been done, so i have done this video hopefully it will pick the nose it makes up.. and someone will know what i need to do
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    bump no one seen this problem before
    Regular Member Craig1985's Avatar
    harwich essex
    When applying the handbrake on vectra c and sigs you shouldn't press the button in? When it clicks it is self adjusting. Also apply the foot brake before applying the handbrake to take up any slack. Does sound a little creaky tho?
    Aug 2010
    Leeds
    Quote Originally Posted by Craig1985 View Post
    I always hold the button in that explains the poor handbrake then will try this later. Thanks.
  1. Handbrake Issue
    By Benners in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2011, 17:04
  2. Handbrake issue
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2010, 23:25
  3. Vauxhall Handbrake Issue on BBC1 now
    By Caterman in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2007, 15:48
  4. handbrake issue??????
    By coylo5 in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2007, 10:33
