Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 123
Thread: Rebuilt engine cranks.but no start
    Mar 2012
    bath
    Default Rebuilt engine cranks.but no start
    Hi have a 2.2 direct had problems before and have ended up taking engine out to rebuild and after six months or so put it back in refitted all parts it now turns over but will not fire up when I turn on key I have eml flashing along wit oil light flashing too it appears that no fuel is getting to to engine any ideas please
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Check its getting fuel?
    Check fault codes and data list when starting?
    Are you starting the engine with the bores 'dry' or 'wet'?
    Mar 2012
    bath
    No fuel getting to the engine
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What where you previous problems?
    have you double checked all sensors are ok?
    can you view any actual data?
    cranking speed etc?
    Quick test is check you have a 5v reference at any of the engine sensors.
    will it run on some carb cleaner?
    Mar 2012
    bath
    Won't start on carb cleaner live data I can get is telling fuel pump relay working
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    If it won't go on carb cleaner get compression checked
    Mar 2012
    bath
    Compressions are good been checked engine has been rebuilt
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Is the timing ok ?
    was the chain/tensioner replaced ?
    is there plenty of oil in the engine ?
    what fault codes are in the engine management ?
    if there is no fuel are the fuel pump and regulators working ?
    what was wrong with the engine to start with ?
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    fuel pump whats the battery like is it good order
    Mar 2012
    bath
    New timing chain kits eml flashes when ignition turns on original problem not reving more than 2500 with rattle then can sproket sheared of bent valves
  1. Rebuilt turbos
    By cont1204 in forum Diesel Engine related
    Last Post: 23rd September 2012, 10:00
  2. Engine and Spanner Light Before I Start The Engine
    By corderz in forum Engine & Drivetrain
    Last Post: 24th March 2011, 18:48
  3. engine rattle on start up
    By craigyboy in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:35
  4. rebuilt and looking good.....
    By ditchp in forum Styling
    Last Post: 12th January 2009, 22:11
  5. Engine died and won't start!
    By Snoddy in forum Engine & Drivetrain
    Last Post: 6th January 2008, 18:10
