I've trawled through loads of searches and can't find it so can someone please tell me how to remove the heated switch on the dash? Thanks
heated seat switch ?prise out with small screwdriver make sure you use a cloth so you dont scratch dash board
I use a kitchen table knife with some insulating tape on the end. Slide it in a few mm into the right hand side of the panel and prise it out just abit.
Then repeat on the left hand side. Its dead easy.
When putting it back place it in straight and push it in to place.
HTH's
Ah just re read you post. Is it the heater panel or heated seat switches?
Thanks a lot lads, yes it's the heated seats switch. Drivers side has stopped working I've checked wiring under seat, fuse in boot, so all I can think of now is swapping the switches over to see if its that at fault. Thanks for your help I didn't want to go fumbling and make an ugly messif its the heat pad it'll stay off as I'm not stripping the leather.
