Thread: Power around the light switch
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Default Power around the light switch
    Hi guys.
    Stuck this here because it's not really a problem.
    I've got a boost gauge on the way that requires power, ground and a connection to the illumination circuit. I'm mounting the gauge in the drivers side air vent to the right of the steering wheel but I'm not sure which colour wire does that, or if I can even pick up everything I need there!
    Anyone else fitted one there?
    Cheers.
    Grantham, Lincolnshire
    63 Post(s)
    Trim : SRi (Rather Modified)
    Engine : 2.0T Maptun (240bhp)
    Mine's on the drivers A pillar, but I took the feeds for it from the back of the dashboard. Grey wire with yellow tracer is your dash illumination any all brown wire for earth and there's a solid black wire on the back of the dash that's ignition live (but test it with a multi meter).
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Ian-Highlander View Post
    Babe. Cheers.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Turns out I need a constant 12v too. Guessing that's around there too? If not, pinch from the radio?
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Red wire should be a permanent 12v.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  3. Replies: 4
    Last Post: 18th August 2012, 08:58
  4. Replies: 17
    Last Post: 16th August 2012, 10:07
  5. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
what colour wire is ignition live on vectra light switch
