Thread: Dual mass flywheel conversion.
    Regular Member andy-j's Avatar
    Apr 2008
    stoke on trent
    Default Dual mass flywheel conversion.
    Has anyone tried one of these or know if they are any good ?
    http://www.ebay.co.uk/itm/VAUXHALL-V...item3f221b944a
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Single flywheel conversions are known to put far too much stress through the gearbox and cause a lot of vibration.
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    the benefits of the DMF is torsional vibration damping.if you fit a solid flywheel you will not only put lots of pressure on your gearbox but on your crankshaft as well. This goes especially for torquey powerful cars which the vectra cdti 150 is.
    This is what I found out when I needed to have mine done at 80K, so I stuck with the DMF and if it lasts me another 80K I'll be happy.
    Regular Member nath-lav's Avatar
    Mar 2011
    newcastle upon tyne
    How much wil it cost to get a new
    Clutch/dmf just out of curiosity ?
    Dec 2010
    chesterfield
    A1 Clutches, check them out on the internet, they have 4 or 5 centers, just find the nearest to you and give them a call. cost me £650 all in just over a year ago.
    Apr 2008
    stoke on trent
    Thanks for your replys, think I'll stick with LUK dmf. It just gets a bit much £500 every 60-80k.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Its mostly down to way the car is driven, driven correctly they will last a lifetime
    Dec 2010
    chesterfield
    Quote Originally Posted by andy-j View Post
    That's what I had fitted LUK DMF and clutch kit supplied and fitted by A1 clutches. If you can get the same fitted for £500 or you can do it yourself then it's a bargain, go for it. Last year when I was looking to get mine done the lowest price I could have it done for was £1000, vauxhall wanted £1350.
  1. Dual Mass To Solid Flywheel Conversion Kits
    By sloper in forum Diesel Engine related
    Last Post: 4th March 2012, 14:41
  2. dual mass flywheel how to.
    By hitcho in forum Engine & Drivetrain
    Last Post: 27th August 2011, 11:52
  3. Dual Mass Flywheel...........again
    By Gaz the Cab in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 22:02
  4. Dual mass flywheel ?
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2007, 20:59
vectra c flywheel conversion
