Likes Likes:  8
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: List of SMDs for a dash conversion
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default List of SMDs for a dash conversion
    As there are no proper lists of the smds required for a conversion i've decided to make a thread containing all the smd/led numbers for each specific part
    Here is a list i've copied and changed slightly (Thanks goes to Ian Highlander for the initial list.
    As you will see the list still needs alot of work as there are no head units listed and a few other things.
    If you have done something (i,e the cd70) say how many smds you used (or any other specifics) and I will add them to the list
    Speedo head (pre facelift with window in rev counter)
    • 14 x plcc2 (mounted on their sides to replace original side mounted LEDs)
    • 4 x plcc2 for right hand LCD (in speedo)
    • 3 x 0603 for left hand LCD (in rev counter)
    Heater control panel A/C models
    • 9 x plcc2
    • 5 x plcc2 (four switch indicators and behind the blue semi circle on the temperature dial, there was one already here but it's never worked on mine, does now).
    • There's a red one already in situ behind the red semi circle that I didn't replace.
    Heater control panel Full Climate models
    Dual climate control models
    • 6 x Side leds/ plcc2 for 3 halos
    CD30
    • 2 x plcc2 for drive slot
    • 4 x plcc2 for centre halo
    • 21 x plcc2 for all other buttons
    CD70
    • 4 x 0805 for drive slots
    • 4 x 0805 for on/off halo
    • 4 x 0805 for centre halo
    • 32 x 0805 for all other buttons
    GID
    This is fitted with plcc4's by default, I replaced these with 0603's on Kmans advice.
    • 36 x 0603
    Drivers door switch (with rear electric windows)
    • 14 x plcc2
    Passenger door switch
    • 4 x plcc2
    Rear door electric window switches
    • 1 x plcc2 in each switch
    Front heated seat switches
    • 1 x plcc2 in each - Switch illumination
    • 1 x plcc2 in each - "seat active" illumination
    Heated seat switch with cooling
    • 3x PLCC2 (2 for backlight, 1 for active)
    Park pilot switch
    • 1 x 3mm led diffused - Switch illumination
    • 1 x 3mm led diffused - Switch active illumination
    Sport switch
    • 1 x 3mm led diffused - switch illumination
    Traction control switch
    • 1 x 3mm diffused
    Alarm switch
    • 1 x 3mm diffused
    Steering wheel controls (half can, three button type)
    • 3 x white 3mm diffused in each switch panel (one per button)
    Full Can Steering wheel Controls (scrollers)
    • 3x 0805 per control. 1 per button
    Headlight switch (non xenon with front fog lights fitted)
    • 11 x plcc2
    Overhead light switches
    • 1 x 3mm led diffused in each switch
    Ashtray
    • 1 x 3mm diffused
    Interior mirror downlight
    • 1 x 5mm diffused ( 2 x 3mm ones next to each will also work)
    Downlight in memory mirror
    • 1x PLCC2
    Twin audio panel
    • 9 x plcc2
    Sunroof switch
    • 5 x 0603 (there's actually 8 but you cant get to the inner three without breaking the switch)
    Rear heated seat switches
    • 1 x 3mm diffused in each switch - Illumination
    • 1 x 3mm diffused in each switch - Switch active
    Powered bootlid button (in bootlid)
    • 1 x 3mm white diffused
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Can anyone add any thing to this?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    • 6 x Sideleds/ plcc2 for 3 halos
    CD70
    CD30
    I've done these from memory but i think they're correct
    Nov 2012
    Denmark
    6 Post(s)
    Vehicle : Opel Vectra
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    Downlight in memory mirror:
    • 1x PLCC2
    Heated seat switch with cooling:
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers guys, can anyone tell me what size of resistors are required for the LEDs and does everything with LEDs need a resistor?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    All the dash switches that have 3mm less on require the resistor. Depending on what brightness of led you're using might depend on what size resistor you use. None of the others I.e. half can steering controls and courtecy light need them
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    I used 1/4 watt, 470 Ohm resistors.
    Other things worth noting, there are different lightswitches and steering wheel controls with the same design. My light switch has 1 LED less than in the pictures (front + rear fog lights and headlight leveling button on both) and the inner parts are NOT 100% interchangeable. The full can steering wheel controls come in at least 2 different designs, 1 with a wire and 1 with just a plug - they're not interchangeable at all.
    Worth noting on the heated seat switch with cooling, event though there are 2 backlight LEDs, it will look funny, if blue is chosen for backlight on cooling and red i chosen for heating, since the light in the little selector wheel comes from both LEDs
    Regular Member Gareth19's Avatar
    Peterborough
    Can anyone confirm if the same LEDs are required for the dials/speedo for a facelift vectra? The op says for preface..
    thanks
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by Gareth19 View Post
    thanks
    Yeah there the same LEDs in the clocks
    Peterborough
    Perfect thanks mate
  1. dash leds list
    By dannyo in forum Styling
    Last Post: 2nd February 2013, 17:16
  2. dash SMDs conversions what colour
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2012, 13:08
  3. smd conversion list
    By IRMSCHER ALBA in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 12:12
  4. Dash smds
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 20:40
Vectra c cluster smd led
vectra speedmotere smd conversion
vectra c dash smds
what size halos fit vectra c
vectra c park pilot switch light change site:www.vectra-c.com
what is diffised led in vectra c switches
what smds go in vectra c clocks
opel signum cluster conversion to opc
https:www.vectra-c.comforumshowthread.php181523-List-of-SMDs-for-a-dash-conversion
