Results 1 to 10 of 11
Thread: Cruise Control randomly drops out... Weird
    Nov 2012
    Birmingham
    Trim : Design (With Extras)
    Engine : 1.9 CDTI (150)
    Mileage : 99,000
    Default Cruise Control randomly drops out... Weird
    Every so often my Cruise Control will turn itself off, usually I notice but it is quite annoying. Any ideas? Its a Vec C 150. Never had this issue before. Runs fine 90% of the time and always turns on no problem.
    13 Post(s)
    First thing to check is the clutch return spring.
    Jan 2013
    Halifax
    Vehicle : Vectra 1.9 CDTI (150) Design
    Engine : 1.9 CDTI (Z19DHT)
    Mileage : 97000
    Hi - Don't know if you've solved this but I had similar problem (Vectra C 1.9 CDTI 150bhp) and tried various things including trying to tighten clutch and brake pedal assemblies. What finally sorted it was when the ECU was interrogated and found a number of errors etc etc. The mechanic checked these (finding little wrong) and then cleared the memory. Cruise control fine since!!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Quote Originally Posted by Brummie View Post
    you could also try cleaning the end of the stalk aswell
    http://www.vectra-c.com/forum/showth...cruise+control
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    I had this exact problem a few months back, it was the alternator lol
    First thing was the cruise control just turning off randomly, next my radio started to shut down randomly, then it was everything lol, finally the power steering would fail and my dash would blink on and off and click like crazy.
    Regular Member d_ghedia's Avatar
    Oct 2007
    Berkshire
    Vehicle : Vauxhall Signum
    Engine : 1.9 CDTI 150. Manual
    Got the same problem on mine... gotta look at the stalk itself... might reqiuire a new one
    Nov 2012
    Birmingham
    Mileage : 99,000
    Tried a new stalk, already had a new alternator. Checked clutch return spring. I think there may be a more deep seeded problem with the engine causing this as I have other engine issues. Thanks for the advice though.
    Regular Member any-mgzt's Avatar
    cheshire
    21 Post(s)
    Trim : basic
    Engine : Z19DT
    I had same problem, and others. Buy some contact cleaner, cheap from Toolstation, WD40 is not really any gooid, clean ABS connector, also remove Indicator stalk and wipe the contacts at the end of the stalk, use cotton buds to clean contacts in CIM, spray switches in outer end of stalk, refit.
    I had criuse problem and EHPS light on, Airbag lights.
    Criuse fixed by doing above. EHPS was a broken wire at the steering sensor. Airbag, cleaned the obvious connector under the seat, on floor, no joy, found connector attached to seat at the front on the frame of the seat, removed that and cleaned, Airbag problem now solved.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Also if traction control gets activated (i.e. wheel slippage detected) this cancels cruise control. I've noticed it in teh past when tyres were getting low on tread and very heavy rain.
    This can be caused as others have said by defective/dirty abs sensors and reluctor rings, tyres having markedly different amounts of treadwear, etc.
    Nov 2012
    Birmingham
    Mileage : 99,000
    Just for reference chaps, it ended up being related to my EGR issue (now blanked) which when it stuck it would often restrict vehicle power and the cruise would automaticall turn itself off. Now I have blanked my EGR I havent had the issue in thousands of miles.
  1. Weird clicking noise from heater control or glove box
    By rollercoaster63 in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2020, 20:53
  2. Cruise Control works but weird issue??
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 8th June 2012, 00:00
  3. Vectra C Cruise Control Drops Out
    By Dogsbodyone in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2010, 10:41
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise control again!
    By Marty J CDTI in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2008, 19:21
https:www.vectra-c.comforumshowthread.php181498-Cruise-Control-randomly-drops-out-Weird
vauxhall vectra cruise control drops outvectra cruise control cutting outwhy is my insignia cruise control cutting outhttps:www.vectra-c.comforumshowthread.php181498-Cruise-Control-randomly-drops-out-Weird#::text=This can be caused as different amounts of treadwear etc.
