Thread: Play in passenger side front wheel hub!
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Play in passenger side front wheel hub!
    Just changed a front wheel and noticed when jacked up, the wheel, hub, brakes all move together with half inch play. There is no dronning wheel bearing noise, but there is clunking/knocking over bumps from the same side. Any ideas? Is it the common drop links or ARB? If so whats costs? Thnks guys
    scotland
    Sounds like the lower balljoint to me , new control arm / wishbone required .
    Sep 2010
    Leeds
    Expensive? Dangerous to drive, ugent fix?? Thanks
    scotland
    not expensive , I done mine was about 40 quid an less than an hour .
    jack it up , turn wheel to side and look in at bottom balljoint to make sure the play is in that .
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds like lower ball joint.
    wouldn't do too much driving like that. Get it checked out ASAP
  1. whine from front passenger side
    By skip85 in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 22:59
  2. play in front passengers side wheel bearing
    By wilsons 1.8sxi in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2009, 17:14
  3. Clunking from Front Passenger Side
    By nick-v2.2 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 14:19
  4. Noised from Passenger Side Front Mirror, Please Help
    By S14RRJ in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2008, 20:42
  5. Front Passenger Side Brake fire??!!!!
    By VinnyPeewee in forum Suspension, Wheels & Brakes
    Last Post: 6th December 2007, 15:07
play in passenger wheel
