Thread: tow bar pins
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    Default tow bar pins
    Hi lads
    How many pin connection do i need i have found sone 13 and some 7 apparantley 7 is old style and 13 is the new style so does anyone have any idea what is more common ???
    Cheers lads
    Dec 2011
    liverpool
    6 Post(s)
    I only will be using this for towing a trailer not a caravan ?? Dont know if this helps like
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Towing electrics?
    12N was the old standard for towing electrics, 7 connectors usually black plug / socket
    12S was the old standard for supplementary electrics, 7 connectors usually grey or white plug / socket, i.e. caravan fridge and reversing lights
    13 pin is the European standard as of September 2008.
    You can get converters to go either way if necessary.
    Dec 2011
    liverpool
    6 Post(s)
    So which one is my best bet to get that most trailers fit to ?
    Quote Originally Posted by Inner Zone View Post
    Towing electrics?
    Oct 2007
    Reading
    Year : 08,08
    Quote Originally Posted by antowens View Post
    12N but what's on the trailer?
    Dec 2011
    liverpool
    6 Post(s)
    I havent got a trailer yet didnt think there was a difference between them all thought they were all standard
    Oct 2012
    Llangollen North Wales UK
    Trim : Elegance
    Engine : 1.9cdti 120
    Mileage : 152000
    If your just going to tow a small trailer without electrical items like fridge interior lights ( as you would have in a caravan ) I would just go for the 7 pin set up, but buy the Vauxhall electrical kit, its about £50 and a ten minute job. Probably the easiest tow bar and electrics I've ever fitted
    Dec 2011
    liverpool
    6 Post(s)
    Cheers mate have you got a part numner for.it but ye just a trailer to power brake lights and such not as i say not a caravan
    Quote Originally Posted by MARTIN FROM LLAN View Post
    Oct 2007
    Reading
    Year : 08,08
    They are just from 2008 caravans moved to 13 pin, trailers could be either.
    Dec 2011
    liverpool
    6 Post(s)
    Looks like i will just have to find someone with a trailer and ask them how many pins there plug has
    cheers lads
  1. are these off set pins ?
    By Tam80 in forum The 'Off Topic' room
    Last Post: 19th September 2011, 10:52
  2. Door Pins?
    By Diet1985 in forum Styling
    Last Post: 8th May 2009, 17:02
  3. door pins
    By mikey c in forum Styling
    Last Post: 5th March 2009, 13:05
