Thread: autobox query
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    Default autobox query
    Ive only had my 1.9cdti sri 150 for about 6 weeks. Had a mas remap done including egr and dpf removal. Ive been experiencing the following and justbwondering if anyone else has had the same symptoms and if its normal or could do with a fluid change. Car has done 88k and as far as I can see has never haf a fluid change.
    When cold, the gearbox seems a little reluctant to change up. I understand itmight hold the gear a little longer to aid warming up but sometimes it feels like I need to chamge it manually.
    When putting foot to floor from standstill, engine warmed up, there is a 2 second delay before the car takes off.
    Finally, sometimes the kickdown is a bit hesitant.
    Any advice please before I go down the route of a fluid change.
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Fluid change is the cheapest you can do right now. If that doesn't cure it (and I don't think it will) you'll have to take it to a specialist. My bet is on the valve body.
    Regular Member Lockstock2012's Avatar
    Aug 2012
    Bristol
    Regarding the delay from standstill - my autobox drops into N after about 10 seconds of not moving - when you go to move off there is a delay (seems like ages but only a second or so) while it reengages Drive - you quickly learn to anticipate lights etc and edge forward before they change meaning you eliminate the delay. Dropping into N is a design feature aimed at helping with emissions etc.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Quote Originally Posted by Lockstock2012 View Post
    Mine does this too. The delay I get is different. Pull away normally and its fine, no delay except the one you describe. But, floor it from stsndstill and it takes a couple of seconds to realise what youve asked it to do and then it does it. Had it in my last car, an mgzt cdti auto and it was rectified by a new maf. Was thinking it wss possibly low or old fluid in the vectra that was causing it.
    Sep 2011
    norwich,norfolk
    How old is the car,what is its mileage and has it been changed before, recommend changing at 40K.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Quote Originally Posted by maud2450 View Post
    Car is Feb 08 on 57 plate. Its done 88k miles. Only bought it in December and no record of previous fluid change.
    Ive read conflicting views on here. Some saying change it every 4 yrs or 40k miles. Other saying dont touch it unless youre sure theres a problem.
    Hence my original post, trying to gauge if they are common problems and if anyone has had similar probs and did a fluid change/topup cure it.
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Don't touch the oil if the gearbox is working ok ! That's the advice given me by 4 different Vx dealerships over 6 years of running a 2.5 VecB auto and a 3.2 VecC auto. (Both cars over 90k when the advice was given, and the VecB was sold on for the VecC, not sold on because of problems, sold on as running perfectly)
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Quote Originally Posted by woodpeck View Post
    But thats just it mate, im not sure if mine is working normally or not. Lol.
    Dont know if the slughish kickdown, hesitancy and holding gear when cold are.normal.for this gear box.
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Well mate, I wouldn't be trying to floor any car, auto or otherwise, until it had at least started to warm up.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    If you read my original post you will see that I stated that it holds gears when cold. But the hesitancy when flooring it is with it fully warmed up. Im quite aware of the dangers of flooring it when its cold.
  1. what autobox do i have
    By jimmywhu in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 07:42
  2. autobox
    By cajagoogoo in forum Engine & Drivetrain
    Last Post: 28th February 2012, 21:04
  3. Anyone done an autobox?
    By cphaza in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2010, 23:20
  4. clunk on my autobox
    By corby-boy in forum Engine & Drivetrain
    Last Post: 4th September 2009, 21:45
  5. 3.2 autobox
    By poves in forum Engine & Drivetrain
    Last Post: 27th November 2008, 10:08
