Thread: Sun visor clips
    Regular Member Jamston39's Avatar
    Oct 2012
    Stockton on tees
    Trim : SRI
    Engine : 1.9cdti 150
    Mileage : 94500
    Default Sun visor clips
    How do you remove the clip in the roof for the sun visor as bellow
    Regular Member coldo's Avatar
    Scotland
    You will need a flat blade crewdriver, needle noise plyers and allot of swearing....
    You have also broken the clip if it's just the metal that is now showing (I also did this.... girrrr...) and you will need to either repace it or bond it back up..
    Put the screwdriver in onse side right at the mounting point and use the plyers to depress the clip.
    It will come out it's just a fiddly wee buger!
    Oct 2012
    Stockton on tees
    Trim : SRI
    Mileage : 94500
    ****** the plastic just came off in my hand and now really can't get the metal bit out at all
    Edinburgh
    Engine : 1.9 CDTI 150
    I am confused, because i pulled the plastic bar out and this was left as the pic above, all i was left with was the plastic bar, clip, spring and plastic stopper. is this not right ????
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Quote Originally Posted by hodge725 View Post
    Yes that's right put it all back together in hand and push it back in roof job done! I did one like that and managed to get one back together with the metal bit in roof still but can be a pain in the behind.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Much easier to remove the metal bit (a thin screwdriver down each side with a bit of pulling usually is enough), reassemble the whole clip onto the metal part and then push it back into the roof.
    Grantham, Lincolnshire
    63 Post(s)
    Trim : SRi (Rather Modified)
    Engine : 2.0T Maptun (240bhp)
    Quote Originally Posted by Neve'o View Post
    You will sit there for ages trying to get the plastic clip to go back in again, you may "eventually" get it, I managed a couple of times after much swearing and pulling/pushing of the clip until someone else pointed out it was much easier to remove the metal part from the roof, re-assemble the clip and push the whole thing back in to the mounting point.
    Scotland
    I snaped the plasic internal part off mine which was down to brute force and wearing at how hard these dam things are to take off... That's what I thought you had also done lol.
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    You have to compress the clip using pliers.
    Believe it or not, that's actually the official TIS2000 way to do it...
    Oct 2012
    Stockton on tees
    Trim : SRI
    Mileage : 94500
    Managed to do it so both sunvisors are now in though the cable for passenger side was tight as it seems short but it's in
    inject need to save for leather interior and headrest DVD player for the little one on long journeys
  1. Sun visor led mod
    By SRIDAN in forum Styling
    Last Post: 13th November 2020, 22:58
  2. Re-attaching Sun Visor Clips
    By Neve'o in forum Bodywork & Interior
    Last Post: 22nd August 2012, 07:42
  3. Sun visor retaining clips
    By stevie16v in forum Bodywork & Interior
    Last Post: 27th September 2011, 19:04
  4. Vectra Visor Clips
    By nick-v2.2 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 23:00
https:www.vectra-c.comforumshowthread.php181338-Sun-visor-clips
