Thread: 1.9 CDTI - What pipe is this?
    Hanging Heaton
    28 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default 1.9 CDTI - What pipe is this?
    Poor pic but its the pipe in the lower part of the pic, comes off the heat shield and has a protective braided hose...
    Had some white smoking from that area when started after cleaning and re seating the injectors, did get cleaning products everywhere like, cleared after few mins...
    Jan 2013
    Hartlepool
    That is a vacuum pipe that goes to the actuator on the turbo
    Sep 2011
    oxford
    If its the pipe that only just visible further down the engine block covered in the braided hose that's pipe that carries exhaust gases to the EGR valve at the back of the engine. It gets pretty hot so anything spilt on there would burn off quickly. On the cautious side they've been known to split and leak exhaust gases.
    Hanging Heaton
    28 Post(s)
    Mileage : 140k
    Yeah the lower one, not the boost pipe...
    Ah, makes sense now. Might have knocked the pipe when blanked the EGR other week... Is cracking common and are they easy to replace?
    Can it be blanked on the front side and lose the pipe?
    Jun 2006
    St. Helens,Merseyside
    if you already have the egr blanked then buy a stainless steel blank and blank it at the manifold, it the egr pipe is damaged/cracked then it wont matter as the blank will be before the pipe.
    i keep saying im gonna sort it out with mine
    Hanging Heaton
    28 Post(s)
    Mileage : 140k
    Will it be the same sized oval blank for the turbo side, slightly convinced that's where it's smoking from...
    Do rads have to come off to get to it?
    Hanging Heaton
    28 Post(s)
    Mileage : 140k
    Looks like this pipe at the bottom to me...
    http://m627.photobucket.com/albumvie....jpg.html?o=49
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    That pipe appears to be :
    93178884 5851952 PIPE,EXHAUST GAS RECIRCULATION VALVE
    Item 2 taken from here :
    http://ecat24.com/opel/catalog/part/...1/41397,41381/
    Hanging Heaton
    28 Post(s)
    Mileage : 140k
    Think its 17, egr cooler... Can this be remover if mapped egr out? Or blanked at the turbo side 18?
    Wheres PaulvectraC when you need him
    Hanging Heaton
    28 Post(s)
    Mileage : 140k
    Just got an email from a supplier of the EGR blanks, gasket can be fitted either side...
    How does the EGR cooler work? Are they prone to leaks on the CDTI's?
  1. name that pipe cdti 150
    By big mick 1981 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 20:14
  2. Where to get a Decat pipe for my 1.9 CDTi 120???
    By Vectra Adz in forum Diesel Engine related
    Last Post: 2nd July 2012, 18:23
  3. 3.0 v6 cdti boost pipe
    By scotty84 in forum Y & Z30DT Specific
    Last Post: 3rd April 2012, 17:48
  4. 1.9 CDTi pre cat pipe
    By Governor in forum Diesel Engine related
    Last Post: 17th January 2011, 21:00
