Originally Posted by
jonnyaykroyd
Does sound like bearings on a pulley. What's the mileage on the vehicle???
Basically you have two belts on your engine.
1/ The timing or cam belt which is a toothed type belt and keeps all the engine in time (pistons and valves that is). There are a number of pulleys on this belt that could be failing and whining. Water pump, tensioner pulley or the guide pulley.
2/ The drive belt which is also known as the accessory belt or aux belt. This belt goes around pulleys on the alternator, AC compressor, an automatic tensioner, a guide pulley and the crank pully.
Mint is suggesting that if you remove the drive belt and start up the engine (ok the AC wont work and the battery wont charge) it will tell you if the problem is on that belt route rather than the timing belt route. If it's the latter you're most likely looking at a timing belt job. If its the former could just be a new tensioner or possibly recon or new alternator.
If its a problem on the timing belt route then its serious as if it the faulty part fails the engine will go out of time and you're look at big repair bill!
