Results 1 to 10 of 16
Thread: inlet change f**k up!!!!!!!!!!
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    Default inlet change f**k up!!!!!!!!!!
    Right changed my inlet manifold on friday went to start it and it just made a crunching noise so tried again then I realised I left the fuel pump locking pins in! So took em out then tried to start it agaib and it was tuening over fine just not firing. So left it where it was over night. Went back in the morning with a guy from local garage took all apart again and the crank shaft has slipped. So towed it back to the garage to get it all sorted hopefully they need to order the special timing tool which is annoying. Wont be doing that again lol woops
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    Ouch! Hope you sort it
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Oops lesson learned always turn over by hand first
    Apr 2012
    littleport
    Feel like such an idiot! Hppe there's no other damage!
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Could have happened to anyone mate. It easy to do.
    fingers xd its ok.
    Apr 2012
    littleport
    It turns over nice and makes the right noises so thinking its fine. Even with all this still saved money lol
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Bottom line is m8 you tried a job (which isn't the easiest either) that most would shy away from - so certainly don't put yourself down. You made a mistake but you have learned not to make it again so if there's a need to carry out the same job - you'll know what not to do.
    Apr 2012
    littleport
    Haha yeah very true. It was quite easy tbh. Looking forward to driving it with working swirl flaps never driven it like that lol. Hopefully abit quicker to move away
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    As critch says - Could have happened to anyone.. Experience says always turn the engine by hand when you have done anything relating to the belt - but honestly, dont beat yourself up over it.. Fingers x'd all will be fine.
    A new GM timing belt should be all you need as that will have timing marks on it so you dont actually need the tool.. Also - if you have jumped a few teath, replace the belt anyway. The last thing you want is a weak belt on there....
    A
    Apr 2012
    littleport
    I've left it with the garage with instructions to change the belt the whole lot was changed before Xmas so will only do the belt. I just want it sorted. But hey poop happened lol
  1. Inlet manifold change
    By LGaffer in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 15:38
  2. Inlet change tomorrow
    By smartalec0310 in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2013, 17:44
  3. Well finished the inlet manifold change
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 22:18
  4. Is there a written how 2 for 1.9 cdti inlet change?
    Last Post: 18th December 2012, 00:59
  5. inlet change?
    Last Post: 17th April 2012, 06:58
