Thread: Urgent alarm help!!!!
    Jan 2013
    North yorkshie
    Exclamation Urgent alarm help!!!!
    Please help, replaced battery after completely dead one and alarm sounds even when battery removed again from car! Won't shut up! Rang dealer as I have just towed it back. They say alarm will need replacing I just need to wait it out, already been sounding 20 mins!
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Quote Originally Posted by Mickey76 View Post
    Need more info bbud what happens when you put key in and turn ign on.
    The sounder has a back up internal battery so if the battery is removed the alarm still sounds same as house alarm sounder.
    I doubt it's the alarm as Its doing what it's supposed to.
    But need more info
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's back up battery
    fit new battery lock and unlock car several times.
    then start car. It should then be ok
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I thought alarm speaker was in boot area and can be unplugged? Critch's solution better as disconnected alarm sound may
    affect insurance claims
    Jan 2013
    North yorkshie
    Thanks guys, the car won't start as its had a replacement cim that the dealer can't/won't program, so no central locking either.
    put keys in ign disconnected battery, took keys out replaced battery then locked n unlocked car via key hole in door- as suggest by dealer. Is this because new cim? Can I put old cim back in with alarm going literally just to silence it?
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Plug the old cim in and try it.
    could also try undoing the wire that's screwed to batt pos
    why have you replaced cim?
    Jan 2013
    North yorkshie
    Northampton
    Engine : A20DTH
    Mileage : 88000
    It might have been a good idea to give us the info about the replacement cim in your first post
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Quote Originally Posted by Critch View Post
    If the keys are not programmed into the new cim then the car won't start and the alarm will sound. I would also try the old cim. Was it the usual fault of clocks dash going dead?
    i think the new cim can be programmed with immobiliser code but not def as I think there was an upgraded cim released.
    just read your other post, it sounded like cim until you said it cut out over bumps ?
    that must be connection cut to feed or earth.?
    Jan 2013
    North yorkshie
    Apologies, panicked a little, puttin old cim back in now....
    not too popular with neighbours
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Urgent help alarm keeps going off
    By johp778 in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2012, 20:46
  3. *URGENT!!* HELP!! Car key fobs wont open the doors and alarm going off!!!
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 20:52
  4. Astra G 1.8 SRi Alarm Problem URGENT!
    By aaruck in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2008, 13:00
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
