Hi,
1.9 cdti 150bhp 136k fsh.
I have posted this problem already but am going to undertake a major strip down of everything I am able to take off and clean....
symptoms are....
1. Start the car from cold and there is a plume of blue-ish smoke, as soon as the smoke has cleared,usually 4 seconds then the car does not smoke at all and ticks over/runs perfectly. (could be stem seals but dont think so)
2. There is only very low down boost from the turbo and boost is hardly noticeable when you get into third gear (not smoking)
3. All the pipes going into the turbo and out of the intercooler are wet with oil. (not been over filled with oil)
4. The throttle body and inlet manifold are both wet with oil.
5. The crank case breather "can" and all pipework going into it are wet with oil.
The car is running sweet as a nut but not boosting anywhere near as it should.
Things I am going to do in the morning are as follows....
1. I am going to change all the boost pipes for new silicon ones
2. I am going to remove the crank case breather pipe from the turbo inlet pipe, blank the inlet off and temporarily vent the crank case pipe to atmosphere.
Couple of questions......
1. If the intercooler is full of oil is it easy enough to remove whilst I have all the airbox etc off?? What do I clean it with???
2. I have blanked the egr valve off but lets say the egr valve is knackered in the electronic side, would this cause the car not to boost properly?
3. Is it possible that the crank case breather "can" thingy is stuck open letting oil into the system and can it be cleaned?
I am going down this route as due to the fact all the pipework is wet with oil and I have no smoke when Im driving which would suggest the turbo seals are ok??
Please if anyone has any further things I can check or tips whilst I have got it all stripped down then please drop a message.
Many thanks,
Paul.
p.s. it has had the new type inlet manifold at some point which is working fine and I have had the dpf removed (15000 miles ago), the boost pressure sensor on the inlet manifold has been cleaned and the egr has been cleaned and blanked off,boost pipes all seem to be swapping pressure ok and no sign of air leaks.
