Hi all, I am looking into changing my wheels and am unsure on what to get, fancy snowflake wheels but saw a set of corsa ARCTIC EDITION wheels, which I liked the look of, does any one have a picture of these on a facelift vectra?
Andy
Andy
They're not likely to fit fella, although I'm not familiar with them. Have you checked the fitting? What size are they? Anything smaller than 17 looks teeny tiny.
They're 18's going by this article.
http://www.carmagazine.co.uk/Drives/...on-CAR-review/
can't see anyone having them fitted. Maybe you could talk someone into a photoshop.
How about these reps?
http://www.ebay.co.uk/itm/18-VAUXHAL...item5652ad9ff1
Arent they just corsa vxr wheels in black?
How about vxr reps
It's these ones I saw I liked the look of.
http://www.ebay.co.uk/itm/VAUXHALL-C...item3cce7b637d
If the stud pattern is 5x110 they will fit the studs i don't know what offset is needed but if the studs the same pattern you could by spacers. Also you could maybe make the fit by gettin a stud adaptor set of spacers! Basically a spacer that has th correct stud pattern for your old studs and studs tovthe pattern of your new wheels, i wanted insignia VXR wheels but would need to do a hub and brake conversion i was told.
