Hi all
ive just picked up a vectra c on 52 plate with a few probs cheep while I'm between jobs.
The first job is no reverse lights. So far....
bulbs ok. Bulb housing wiring and connectors ok to boot fuse box.
Reverse switch ok. I have 12v at the switch on white/black and when in reverse I get 12v out on the brown.
im assuming the brown continues through various connectors to the boot and plugs into the fuse box. I can only see one brown wire connected into the fuse box and it has no voltage so I'm guessing there is a break or bad connection somewhere.
Can anyone confirm which wire plugs into the fuse box from the reverse switch? And also the journey it takes and does it stay the same colour?
Many thanks
barks
