Been having this problem since I got the car over a year ago. You can push the accelerator peddle 1/4 way down before engine begins to rev. Can anyone tell me what's up with it. It's really getting on my nerves now lol cheers
A shot in the dark, could the pedal sensor be dirty??
Is that in the top of the peddle and how to I remove and clean lol
You can test it to see if its reading ok with a volt meter
Will check it out. Cheers
Or access to tech2 or other software, u can see the percentage i think it was, it'll show responsive readings.
As to removing it, cant help as i havent done that but read it somewhere on this forum about it.
Ok cheers. How can I get a hold of the tech2 softwear
Of course it could equally be at the 'other end' too ... Throttle position sensor, gunged up throttle body, actuator problem... I'd give the throttle body area a good clean and check, just to be sure everything is clean moving freely before moving on to the more difficult to check sensors, etc.
