Results 1 to 10 of 14
Thread: Body control unit
    north lincolnshire
    Default Body control unit
    I have been informed that my front wipers have stoped because the BCU has failed,is this unit likely to be responsible for the alarm going off when it feels like it?
    Clive
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I'm not sure the BCU has much to do with the wipers.
    In the engine fusebox, try checking F5, F11, F14, F22, & F34.
    However the wiper motor itself can have a fault with the self park earth connection.
    Good Luck with sorting it.
    north lincolnshire
    Thanks Tony I will pass this on to my tame mechanic
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Wipers I would put down to either motor at fault or cim fault
    as for alarm it it could be a number of things. Window sensors and ultra sonic sensors being most common
    north lincolnshire
    Quote Originally Posted by Critch View Post
    Please excuse my ignorance but what is "cim" please?
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    Quote Originally Posted by clive.22 View Post
    Column Interface Module.
    It's the canbus module that interfaces the steering column controls to the rest of the car.
    north lincolnshire
    Quote Originally Posted by Hue Jarse View Post
    Doesn't anybody use wire any more?
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Haha, Yes, they do use wires still. Very thin ones usually.
    And they also do things like having resistors in the switches.
    For example a Electric Window switch which when pushed to, say, open the window is earthed via a resistor which drops the 12v on the wire to, say, 9v.
    To close the window the same wire is earthed via a different resistor and this drops the voltage to, say, 4.5V.
    And all this is controlled by the individual Door module which is also on the Canbus network.
    And there is a lot more.
    When you push the brake pedal it sends a signal to the REC in the boot and this module tells the individual bulbs to light up.
    The brake light switch also sends signals to the Engine Management system, whilst the REC sends signals to the Engine Management system, the ABS and the Auto Gearbox if fitted.
    Now the Headlight Switch.............................
    But you get the idea.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    I work at a place making buses, the electronics would fry your head! E.g. To turn on an indicator.... Signal goes to main ecu, which sends a signal to a node at the front to tell the front indicator to flash. Meanwhile another signal goes to the rear node... So basically 3 computers to flash 2 bulbs!
    north lincolnshire
    Quote Originally Posted by TonyP2020 View Post
    Quote Originally Posted by stevoxsi View Post
    Anybody got a users manual for black magic and hocuspocus
  1. Body Control Module
    By 1973andi in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 23:24
  2. body control unit
    By jstal40024 in forum Bodywork & Interior
    Last Post: 13th September 2009, 22:05
  3. GSI Body Control Module?
    By 900ss in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 08:56
  4. where's the body control unit
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2008, 21:53
  5. Body Control Module ?
    Last Post: 23rd July 2008, 18:39
