Thread: Remote Door Mirrors
    Mar 2012
    Dewsbury
    confused Remote Door Mirrors
    When I select the right door mirror for adjustment the left one moves as well as the right? However, when I select the left this moves indepedently. Any thoughts?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Meant to be like that. RTFM Set up the right, then the left. Then if anyone else drives the car they just adjust the right and the left will follow
    Mar 2012
    Dewsbury
    Thanks Ziggy, Never noticed it before Doh!!
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Mine wasn't like that before it got plugged into dodgy-com!
    Grantham, Lincolnshire
    63 Post(s)
    Trim : SRi (Rather Modified)
    Engine : 2.0T Maptun (240bhp)
    Quote Originally Posted by BigWilko View Post
    It's an option you can turn on and off from Tech 2. So you can have them operate as described above or completely independently of each other (I believe).
    slough
    the early vectra `c` didnt have that as my friends and i had them at 52 plate.....they moved indpendantly
    13 Post(s)
    Quote Originally Posted by hippo View Post
    Happened sometime in 2003/2004 IIRC.
    As quoted from a 2003 user manual,
    Adjusting exterior mirrors: Four-way switch on drivers door
    Press switch for left or right hand mirror: four-way switch operates the corresponding mirror.
    However, quoting from a 2004 user manual,
    Adjust exterior mirrors
    If the RH mirror switch is pressed, the four-way switch adjusts the drivers mirror and the passengers mirror, and if the LH mirror switch is pressed, only the passengers mirror is adjusted.
  1. Remote/central locking issue with driver door
    By Archaon in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2010, 08:49
  2. Door mirrors
    By seagipsy in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 17:26
  3. Door Mirrors 1st try!
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 21:23
  4. Folding mirrors - from remote
    By Jay-C in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2007, 16:37
  5. Door Mirrors
    By brianjamesreed in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2007, 09:34
