Results 1 to 2 of 2
Thread: How to remove coolant hoses to heater matrix?
    Jan 2012
    Yorks
    Default How to remove coolant hoses to heater matrix?
    I'm getting no heat out of my Vectra's heaters. The thermostat seems ok (the temperature gauge goes up to about 85-90 and stays there). The pipes going into the heater matrix are different temperatures, so I think there is a blockage. All the instructions say to remove the pipes and flush the matrix out with a hosepipe, but I haven't found anywhere saying how to get those hoses off! They aren't very accessible and don't have any obvious clips to undo. Can anybody tell me how to get them off?
    They are the two pipes going from the engine to the area behind the centre of the dash.
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    There are 2 circlip type clips.lift them up with screwdriver to release and pull them up,pull hoses off the pipes,may need a little wiggle as you do them. Had same on mine just used pressure washer up against the metal pipes and flushed both ways a few times, found it best to refill system car uphill a bit seemed to reduce air lock. Heaters now piping hot.
  1. heater matrix
    By strothrc in forum Engine & Drivetrain
    Last Post: 13th March 2012, 13:31
  2. Heater matrix!
    By SUBEK in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2011, 15:43
  3. Heater matrix now done
    By adfrodsham in forum Bodywork & Interior
    Last Post: 24th February 2010, 23:00
  4. Just Changed Heater Matrix...
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 15:04
how to remove the hoses from the heater core of a corsa c
corsa d heater matrix removal
remove heater matrix corsa c
how to remove vectra heater hoses
zafira heater hose removal
vectra c heater matrix removal
vauxhall removal pipe from heater matrix
how to remove a vauxhall combo heater matrix
removing corsa c heater matrix
how to remove heater matrix pipes at dash on corsa c
opel omega heater radiator removal
removing heater matrix pipe on corsa
how to remove zafira heater pipes
vectra heater hose removal
how to remove vectra c hose clips
remove vectra c coolant hose
vauxhall zafira heater hose removal
vauxhall coolant hose removal
corsa c matrix heater removal
how to remove vauxhall heater hose
vectra c v6 how to remove radiator hoses www.vectra-c.com
