Results 1 to 3 of 3
Thread: help!!!!!!
    Jul 2011
    Nauplio
    Default help!!!!!!
    Hi, i have an opel vectra 1.8 GTS 07 with 220.000 km on the clock. 2 days ago i changed shock absorbers with the koni yellows fitted on stock springs which are already 15mm lowered.
    Today i noticed that the front of the car sits 10-15 mm higher than the rear (measured from tire to wheelarch). Tires are 225/45 17
    Do you guys know if its normal or if i need new springs ?
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    you'll find that the front wheel arches are about that much higher than the rears .
    take the measurement from the ground to the wheel arches and you will see.
    most ppl get more of a drop on the front to compensate this .
    Jul 2011
    Nauplio
    I measured from ground to wheel arches and i found its almost the same.
    Then i dont need new springs, right ?
