Thread: Cricket Noise
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    Default Cricket Noise
    Hi All,
    Since buying my Vectra 1.8 ls 2003 in October 2010, whenever I have the heater on there is a "cricket" type noise from the left air vent. So far I have cleaned out the air vent, took the pollen filter out and vacuumed all that area out. Today I removed the glove box and noticed that the wire connected to the fan is making the noise.
    When I hold the block down the noise stops, initially I tried a cable tie. I wrapped the tie around the block and then around the plastic bit holding the glove box in place. This stopped the noise for a short while, but the rattling started again, I then lodged a scewdriver in there to hold the block down and its been fine since
    Anyone got any better ideas on how to fix this please?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Quote Originally Posted by Wolfie01 View Post
    Hi All,
    if its the same what i had its the glovebox rattleing
    if you tighten the 5 torx screws up tight this will stop the rattle . Torx Screwdriver (T20)
    Nov 2010
    Wolverhampton
    Quote Originally Posted by vectra ste View Post
    Ste, its not the actual glove box as i've removed this and its in the boot!
    The noise is coming from the connection to the fan behing the glove box
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    i see
    i have got a click noise this is when i turn the heater on i believe its the relay
    turn your heater off see if that helps.
    Nov 2010
    Wolverhampton
    Yes it stops when the heater is off, may just leave the screw driver lodged in there and put the glove box back in as this cures it!
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    20 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    If a screwdriver wedged underneaath the block (connector?) helps, then why not tie a tie wrap around the block instead. The screwdriver could get knocked loose, you'd think.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    so the noise {cricket} is on when the heaters running then?
  1. What happened in the Cricket today??
    By BigMan in forum General Chat
    Last Post: 8th January 2008, 06:26
  2. cricket
    By simon5800 in forum General Chat
    Last Post: 30th July 2007, 10:37
  3. Cricket
    By SelbyVX in forum Comedy & Humour
    Last Post: 25th January 2007, 20:42
  4. Cricket Noise in Climate Control
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2005, 15:00
