Results 1 to 10 of 11
Thread: SRI CDTI Blue smoke on startup
    Midlands
    Default SRI CDTI Blue smoke on startup
    Hi,
    New to the forum, seems like on cold get a cloud of blue smoke and occassional judder at low revs, I've just purchased OP-COM and checked the car for any faults, nothing recorded which is a good thing but concerned with the blue smoke. It's seems like a slight misfire when it's juddering, I ran the special tests in OP-COM which should report values for the 4 injectors, unfortunately all the 4 values displayed were 0.00 and did not change even though I rev'd the car. I expected some deviation from the special tests so concerned why it was just displaying 0.00.
    Any help greatly appreciated.
    Suky
    Aug 2010
    Leeds
    They all do it to some point on first cold start a puff of blue smoke.
    CDTI engines.
    Midlands
    Default Blue Smoke
    Hi,
    I've had the car for a couple of years now and have never seen it blow out blue smoke at startup, I'm not an expert but my gut feeling is that something isn't quite right, espcially the judders at low revs.
    Suky
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    Mine done the same early last year having never done it before, only when cold and on start up, i tried everything and after further investigation i found i had one knackered glow plug, replaced it and problem solved, its never done it since..worth a check on yours..
    Midlands
    Is there a way of finding out if I have a faulty glow plug using OP-COM as no faults are recorded when scanned using OP-COM ?
    Jan 2010
    stockton on tees
    yes mate they are easy to check, remove the plug from each glow plug, run a wire from the live on your battery, touch the live on the tip of glow plug and if you get a little spark on contact the plug is fine, no spark its knackered. If you do find a knackered one, remove it, connect an earth to the glow plugs body at the top ( like where the socket goes to remove it ) and touch the tip again with the live wire, you will find its doesnt glow. I removed and checked all mine and found the knackered one was sooted up more than the rest..
    Aug 2010
    Leeds
    The best way to check a glow plug is to remove them
    See if they glow for no more than 3 seconds as you will burn them out & yes you can just replace one but then it will happen again.
    Buy a set of 4x and the 120 8v is a bit of a pig to do.
    Jan 2010
    stockton on tees
    i changed my faulty glow plug coming up a year ago and have had no issues and its still working fine, yes i agree replacing 4 with new is the correct way to do it but i dont see the point of throwing working ones in the bin, i will replace them as and when needed..
    Aug 2010
    Leeds
    Quote Originally Posted by lee1828 View Post
    Yes thats a fair point.
    But id replace all 4x glow plugs as i would all 4x spark plugs and these would be working plugs too.
    Shop around there not all £21.00 per plug you can get them much cheaper.
    Oct 2010
    north wales
    Quote Originally Posted by sukyb View Post
    Hi,
    Suky
    Ive got exactly that, apperently its the swirl bar on the 150 sri that is the cause.........
    New inlet manifold...
    Not cheap around £400
  1. Little puff of Blue smoke on startup...
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 13th August 2012, 11:06
  2. SRI CDTI 150 Blue smoke on startup
    By sukyb in forum Engine & Drivetrain
    Last Post: 15th February 2011, 13:47
  3. blue smoke on 1.9 cdti 150
    By big nath in forum Engine & Drivetrain
    Last Post: 26th November 2010, 09:44
  4. Blue Smoke on Startup SRi CDTI 16v Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 19:09
  5. White/blue smoke at startup
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 27th March 2008, 08:57
why does my vectra have blue smoke on startup
vectra cdti blue smoke on startup
blue smoke at startup vectra c
z19dth blue smoke
https:www.vectra-c.comforumshowthread.php127915-SRI-CDTI-Blue-smoke-on-startup
