Results 1 to 10 of 11
Thread: EGR removal on cdti 150 again !
    Regular Member aps's Avatar
    cheshire
    Vehicle : Vectra C Sri CDti 150 (satnav)
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Default EGR removal on cdti 150 again !
    So , ive just taken a look at it with a view to taking it off & cleaning it ..
    ( i have all the symptoms that goes with it )
    After doing a lot of research prior to having a go , along with print outs at the ready ... the EGR i have looks totally different to all in the "how to's " while its on the engine !
    Looking at the EGR from above , electrical connector to the left ... i was under the impression there should be a corrigated pipe to the right , but as my luck usually goes there isnt !
    The pipe goes from the underside of the EGR down , single metal pipe & i cant even see what type of tool i need , pressed my finger against the bolt to see what the head was and it doesnt look like a torx by the dent in my finger ... so i have NO CLUE !
    any info would really be a help as reading up on people who have done this just say " remove the egr" yep .. very simple if you know the correct tools / screws etc required .
    thanks in advance.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    There's 2 (10mm i think) bolts that hold the EGR valve to the pipe. Undo and remove these, then remove the 4 13mm bolts that hold the EGR valve to the inlet manifold. Becareful not to lose the metal gaskets from the manifold side and the bottom side.
    cheshire
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by mally View Post
    Mally
    These 10mm bolts are they torx head or ?
    didnt seem to feel like a bolt head .. ill go check again
    thanks again
    cheshire
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Another check ... no clue still what the bolt heads are ...
    to clarify
    as mentioned i see the 4 bolts (13mm) i can see the pipe underneath the egr (10mm?) but these i have no idea what type they are and they do look to be very awkward to get to !
    any more ?
    thanks
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    The 3 13mm bolts go in from above.
    Have a look at the picture below. Robbed from another thread, and modified.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Or, i may be wrong with the bolt head measurements, but those 6 are the ones to remove.
    cheshire
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Ok .... managed to remove & clean the egr and as i suspected would happen the car no longer starts , so to be honest the way im going now is to replace the egr altogether .. i am led to believe the part number is 55215031 .. is this correct as the one installed to car now has a number : 55194735 !
    the only other number on it was 50024005/ 05T138
    any advice please ?
    PRESTON
    55215031 Is the current part number as supplied from the stealers and is correct for your car.
    cheshire
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by barney490 View Post
    Lovely stuff !
    thanks for the help ... now ordered & will be with me tmrw
    Very quick to surrender i think .. just couldnt be bothered to start taking it all apart again .
    thanks again
    PRESTON
    Quote Originally Posted by aps View Post
    Lovely stuff !
    thanks again
    Sometimes you have to know when to stop flogging a dead horse!!! I'm sure a new one will fix her right up.
  1. ECU Removal - CDTI 150 facelift
    Last Post: 3rd February 2013, 22:26
  2. Cdti turbo removal
    By jofenan in forum Engine & Drivetrain
    Last Post: 8th May 2012, 18:09
  3. cdti 120 Thermostat removal
    By wrighty11 in forum Engine & Drivetrain
    Last Post: 12th April 2012, 09:06
  4. DPF removal companies for 3.0 CDTi
    By zerocool in forum Engine & Drivetrain
    Last Post: 11th December 2011, 01:07
  5. Cdti pre cat removal
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 7th September 2010, 18:01
