Thread: Spanner warning light
    Leeds
    Default Spanner warning light
    I have just had my manifold changed my the dealers. Thankfuly under warranty. However can anyone advise as to whether it is normal for the spanner warning light to remain on when you turn the ignition on (without starting the engine)? As soon as I start teh engine it goes out with all the other lights! The car is a 2006 1.9 CDTi 150. The dealer syas that this is normal .
    Regular Member ptrehearn152's Avatar
    norfolk
    no this is not normal, would suggest take it back to whoever did the manifold.
    13 Post(s)
    If it stays on until the engine is started, then a fault code is stored in memory. After a certain number of clean start ups or period of time the stored fault code will self delete.
    Either get them to read out and delete the stored fault code, or just wait for it to self delete.
    It's when it stays on when the engine is running that you have to start worrying.
    it's indicating you had a fault that is no longer there. It will clear itself.
    Essex
    My EML stays on when the ignition is on and when the fault finder machine is plugged in it states no faults found. Are we sure that when on stage 2 of the ignition the EML should go out???
    Regular Member YT07's Avatar
    south cumbria
    mine stays on when the ignition is on but goes out when the engine is started,as above i have no faults stored.
    Essex
    I take it you have no EML come on when the engine is running?
    south cumbria
    no mate not a single light and the car runs like a dream.
  1. Car with spanner warning light
    By Handles Sri in forum Engine & Drivetrain
    Last Post: 26th October 2012, 14:52
  2. Spanner Warning Light
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 18:13
  3. car and spanner warning light
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 01:49
  4. Spanner warning Light
    By slipperysam1984 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2009, 17:00
  5. Car with spanner warning light
    By DennisTheMenace in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 07:47
car and spanner warning light vectra c
