Thread: Non Vauxhall, but need help.
    Oct 2010
    Stevenage
    Default Non Vauxhall, but need help.
    Hi guys, i know this is a non vauxhall question, but really need some help.
    My missus has a renault megane coupe and its started to make a knocking/rumbling noise from the front. It only seems to make the noise when turning under power, mostly right but sometime left. If you take you foot off the power when turning the noise stops. Does any one know what this could be. There also seems to be quite a bit of movement from the gear stick, moves back and forth when putting on power and taking off, i know the mounts are a trouble spot for these gearboxes, could this be causing the noise??
    Aug 2010
    Leeds
    Seriously have the mountings checked and the drive shafts too before it falls out.
    Sep 2009
    middlesbrough
    My mams had the same problem with the gearstick on her 2001 megane coupe up until getting rid last month, she had it from a year old and it only had 35000 miles when she scrapped it, the gearstick would move on acceleration and de acceleration from the day she bought it and didn't get any worse so I don't think it's that, I know it sounds stupid but has a cover come off underneath and scraping on the floor or when I had my BMW the arch liner moved and it made a horrific noise when turning left when it would catch the wheel
    Jan 2010
    glasgow
    hi mate the gear box&engine mounts are a weak point on the megane just out of intrest what engine size is it? as some are fitted with a dephazer wheel and this also makes a knocking rumble noise
    Oct 2010
    Stevenage
    Its a 1.6 16v 2000 reg. Im thinkning its either drive shaft or the bearings have gone, but odd that it only does when under power.
  1. The vauxhall is dead, long live the Vauxhall!
    By Matt8 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2011, 16:42
  2. Don't think I'll buy a Vauxhall again
    By Fruit'n'nut in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 13:53
  3. Replies: 9
    Last Post: 14th October 2008, 23:42
  4. Replies: 10
    Last Post: 19th May 2008, 23:32
  5. Vauxhall owner who turned to SAAB, now back to Vauxhall
    By scotty_11 in forum Introduce yourself.
    Last Post: 22nd May 2007, 16:32
