I'm trying to get all the bits together for the park pilot, but I need to take the n/s/r interior boot panel off to get at the fuse board.
Does anyone know how to do this?
I'm assuming it's a mixture of screws and broken plastic clips!
If it's the same as the estate (and I'm not sure it is) then the top plastic panel has one torx screw at each end and then pulls out (it's clipped in at the back so needs a little tug) then remove the trim piece over the fusebox that just sits in place with no clips. The main carpet side panel is a little more fiddly but you can see everything you need with the top off.
Best pic I've got to hand sorry.
Maptun Tuned 2.0T Estate - click HERE for mods list.Brentwood 2012: Winner, Saturday Show. Hull 2012: Winner, Best Estate. Hull 2013: Winner, Best Estate & Runner Up, Best I.C.E
From what I can tell, I need to take the rear left seat belt top bracket off first, then remove the panel behind it before getting at the rear panel.
I had a look last night and I can't see any screws.
The park pilot instructions show the main panel (top and side) as a single piece.
Just after some advice before I start breaking things.
