Results 1 to 10 of 15
Thread: Signum 2.2 direct misfire under load
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Angry Signum 2.2 direct misfire under load
    My signum has been acting a right pig this week, ticks over fine but once under load it starts to sound like a scooby :-(
    I have replaced the spark plugs with the proper Ngk Ones and it's still like it I also looked in the service history and the coilpack had been replaced around a year a go.
    I just had it plugged in to the diagnostics and all that's coming up is "misfire cylinder 2".
    Any ideas what it could be?
    Cheers big rich
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    burnt valve how many miles?
    I would fit gm plugs they are the best
    birmingham
    Engine : 3200
    68k
    Aug 2010
    Luton
    have you got a code reader? if you have swap a coil amp from say 3 to 2 and see if the misfire goes to 3
    birmingham
    Engine : 3200
    Quote Originally Posted by markj23 View Post
    The coilpack in in a fixed row of 4 so can't swap them round ...... I just hope the cambelt ain't jumped an done damage :-(
    Aug 2010
    Luton
    find benny but I think when cam chain jumps it smashes the rockers
    Quote Originally Posted by big rich View Post
    I'd like to see that, as it doesn't have one!
    Could be air leak related or even the coil pack again.
    birmingham
    Engine : 3200
    I know it's a chain.
    Regular Member noel.nev's Avatar
    Pen-Y-Bryn S.Wales
    fuel pump made mine miss really bad b4 it died
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like the start of the fuel pump/reg problem mate. If its the older Siemens pump then odds on.
  1. Signum 2.2 direct misfire - fuel pump?
    By jgs1000 in forum Engine & Drivetrain
    Last Post: 4th May 2012, 05:33
  2. Signum 2.2 Direct - misfire?/vibration/poor acceleration
    By Fenris in forum Engine & Drivetrain
    Last Post: 31st July 2011, 23:32
  3. 3.2 V6 Petrol GSi Misfire Under Load
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:22
  4. Misfire under load. 2003 1.8 DuelFuel.
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 8th April 2009, 23:22
  5. Engine misfire? when under load
    By SYMON in forum Engine & Drivetrain
    Last Post: 15th September 2007, 15:09
vauxhall signum 2.2 direct misfire
vauxhall signum 2.2 direct miss
