Results 1 to 10 of 17
Thread: Window Washer
    Jul 2010
    Default Window Washer
    The washers on my 2003 2L Dti have almost stopped working. The water comes out in very weak jets. I suspect that this is the filter as I had the same problem on a previous vehicle, so where is the water washer filter located please. Manufacturers usually fit them well out of sight and difficult to get at !
    Any ideas please
    Grantham, Lincolnshire
    63 Post(s)
    Trim : SRi (Rather Modified)
    Engine : 2.0T Maptun (240bhp)
    Its on the bottom of the washer pump that plugs into the fluid reservoir under the passenger side wheel arch behind the liner.
    13 Post(s)
    Quote Originally Posted by dc6839 View Post
    Mentioned in the how2
    Jul 2010
    Default Rear Windscreen Washer
    Great, thanks a lot, really good info.
    Also found HERE
    sunderland
    My mother has this same problem... But I've took the motor out and cleaned what I can, that didn't work so I went to the local scrappy and bought another one and I still have the same problem
    And it seems to be worse. Bearly anything coming out now.... Any ideas ?
    13 Post(s)
    It's not the motor you have to clean - it's the filter. See the how2 mentioned earlier in the thread for further info. It also helps to flush out the washer bottle otherwise any sludge left in it will just clog the filter up again - speaking from experience as I had to clean my filter 3 times because of the sludge left in the tank.
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    I had the same problem, ive resorted to running my own pipe from the pump with a non return valve up to the washers now works perfectly so i put it down to the original pipework being at fault somewhere
    sunderland
    Hi mate
    Sorry yeah it was the filter I washed.. How do u flush the bottle out coz I've tried put it just drips. I let it dripping for an hr and and it was still half full
    sunderland
    Quote Originally Posted by bensterzback View Post
    Did you do the rear washer as well coz it the same on the rear?
    If you did was it a big job ?
  1. Blooming Window Washer Jets
    By sjboyington in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:56
  2. Rear window washer
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 23:00
  3. window washer not working
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2009, 15:29
  4. window washer problem
    By patrick1062 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2008, 17:47
  5. Rear Window Washer?
    By PTC8 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 21:39
