Results 1 to 10 of 16
Thread: Anybody else had this?
    Sep 2009
    middlesbrough
    Default Anybody else had this?
    Iv recently bought an Sri cdti 150, I bought it knowing the swirl valve control rod had fell off the manifold, the car was struggling to accelerate below 2k, iv bought all the parts and it's booked in Tuesday but on Friday a took the egr valve off and the plunger was seized solid, after a good clean the plunger is moving freely and the car is running perfect and has been since i cleaned it, I'm just wondering if anyone else has had a bust Inlet but had no problems with their car, its still going in on tuesday but it just seems strange
    One other thing is at about 1500-2000 rpm there is a whistle from the turbo, I have read on other posts that its perfectly normal and some cars are louder than others but on other posts it says it's a sign the turbo is on it's way out, like I said above though the car is running fine and the turbo spins up like you would expect, cheers
    Regular Member badback's Avatar
    Runcorn
    My swirl bar has been off for about 30,000 miles now, the car runs just the same as when I bought it 3 and a half years ago. Fingers crossed it stays that way. I'll replace the manifold if it affects the cars performance but as yet it's running fine.
    Sep 2009
    middlesbrough
    So it could last that long, lol iv bought all the parts and it's getting done tuesday, nevermind it needs the cambelt doing anyway
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Yes the car can run fairly normal with the bar off, But usually it may be slightly lumpy on start up & obviously the swirl flaps inside the manifold don't move to give extra flow or less flow when required, The main nuisance for most people are the fumes that get sucked into the cabin when at standstill or slow moving, I've also had varying degrees of egr build up including being jammed causing a hellish effect by revving & dropping continuously (on/off/on/off/on) until i smacked it with a hammer to unjam the egr. Thats why i fitted the fiat semi blanking gaskets! & only get a light sweating effect in there now.
    Sep 2009
    middlesbrough
    Yes I'm thinking of changing the gaskets once he manifold Is done, do you have any idea about the turbo sound? Cheers for the replys
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    All 'normal' cdti's have a whistle/wheezes so its nothing to worry about, if it gets very loud or effects performance it could be turbo hose related (split).
    Sep 2009
    middlesbrough
    If it was split would I notice a difference in performance, also just looking at my new inlet from autovaux and just want to double check it's the modifed part, the part no is 55210201 and there's another one below it 55182684, cheers
    Sep 2009
    middlesbrough
    And also iv got a new waterpump but I seen on another thread that there Re 2 different types for a 150 cdti. Autovaux didn't tell me they were 2 so could anyone confirm this? Cheers for all the help everyone
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    When i brought mine for the 150 nothing was said about there being two.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by the-wizard View Post
    Yip there is two 150's.
    Gazza4
