Results 1 to 3 of 3
Thread: auto box oil change not happy
    prestatyn
    Default auto box oil change not happy
    hi all had my 07 cdti 150 auto gear box oil changed was told from vauxhall i would need 3ltrs but the garage i used has only used 1ltr,when traffic lights go to green i feel i have to wait 1 sec for it to engae or it will clunk this is a very minior thing and if its still like this after i rechange the oil i will still feel better,is there a how 2 or any advice on how to change fluid would be great,vx said the drain plug is on the torque converter case what is the easiest way to fill it up i have also read you need to drain it 3 times but not sure cheers guys
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    ~3 liters on every change. I would do it at least twice, if not three times 3 liters. Drain and fill are the same hole. It's a 2 piece draining screw: one is the screw itself, the other is the oil dipstick. Remove the screw first, it will drop ~1 liter. Remove the dipstick second, it will drop another ~2 liters.
    Plug the dipstick, fill oil exactly the quantity you removed, then put the screw in the dipstick.
    Drive at least 100 miles and redo operation at least once.
    That's it! Not a big/difficult thing.
    prestatyn
    cheers for that pal,should i complain to the garage
  1. Auto Gearbox Oil Change
    By rocket999 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 19:46
  2. Auto Box Oil Change
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 30th January 2011, 22:46
  3. Auto box oil change
    By churchill254 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 15:53
  4. Auto box oil change & VX stealers
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2008, 15:18
  5. Auto gearbox oil change
    By Elevonic in forum Engine & Drivetrain
    Last Post: 28th August 2007, 12:45
