Results 1 to 10 of 19
Thread: Play in front wheel
    Shropshire
    Default Play in front wheel
    Hi Folks,
    Just being and had two new front tyres at the garage and the mechanic came and told me that my car has to much play in the nearside wheel (possibly wheel bearing)
    I've changed bearing before so thought it would be easy and cheap to sort but just realised its a whole sealed hub and qouted £124 a side from my usual reliable parts place
    I've not heard any humming or droning sounds so can there be any other cause for thye excess play
    Note - My car lost it on the ice just before christmas (see thread, pics on page 2) http://www.vectra-c.com/forum/showthread.php?t=124355
    the nearside wheel hit a grass/mud kerb quite hard could this have anything to do with it ??
    Any Help for this this confused lassy would really be apreciated
    Thanks Guys
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    how hard was the hit did you not even lose the wheel trim?
    cant quite see in pics but doubt that would cause bearing damage but like most things they are strong in the direction they are meant to be used but put pressure on in a different way and they give up
    Shropshire
    Impact was at about 30mph but just sort of rebounded off
    The hub stayed on and isn't damaged or cracked
    The tyre ended up with a tiny pin hole and very slow punchure but the everything seemed fine at the time of checking
    Aug 2010
    Luton
    get it checked somewhere else!! females and garages = pound signs in the eyes for the majority of garages would not think it was a bearing/hub gone
    Shropshire
    I turned radio off and listened all the way home from work tonight (about 16 miles of pot holed country roads)
    There's NO droning, humming, whiring, banging, klonking, knocking ........ nothing
    Only thing i can hear a very very low speed is the creaking of arb bushes that are getting to point of replacing.
    Im out putting new front bumper and ns wing on tomorrow so will jack it up and shake the hell outta the wheel lol
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Could be a ball joint if play in the wheel. Happened on my old Astra. Hit a herb at about 25 mph and from then on, there was play in that wheel. Turned out to be a track rod end
    Shropshire
    Right new bumper and wing on - looks alot less like a banger car now lol
    Wheel does have play in it
    When you yank it at 9 and 3 0clock its very noticeable at 12 and 6 0clock it hardly moves ??
    I wondered track rod end too - but its ****ing down now so can't go and investigate
    Will hopefully be able to jack it up and have a proper look next weekend - mot soon so will have to sort it out before then.
    Thank you guys
    Engine : 1.9 CDTi
    Could be track rod end or inner rack joint.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Play at 9 and 3 o'clock almost certain track rod end
    Shropshire
    UPDATE :
    Righty oh folks, this is what i've changed so far :
    NS Steering Rack End (Drumstick shaped thing)
    NS Track rod End
    NS & OS Droplinks
    I took the car to have the tracking done after fitting the above parts, i've since being back 4 times as the tracking is still out !!
    The supervisor did the tracking himself today and said he got it spot on front and back (four wheel alignment) but im still having to hold the steering wheel about 5 degree's to the right to get the car to go in a straight line, if the steering wheel is central the car pulls to the left
    There is now a rattle / knock coming from the drivers front area
    Im stumped - please please help ........................... is it damage to the steering rack from my 360 skids on the ice by in december (only hit grass/mud bank with the passenger wheel, did 360's along the road then collided with hedge on NS)
    Any help would be much appreciated
    Thank you
  1. play in the steering wheel
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2016, 18:21
  2. Play in passenger side front wheel hub!
    By Jow20 in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2013, 14:25
  3. play in rear wheel
    By micks edition 100 in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2009, 21:31
  4. play in front passengers side wheel bearing
    By wilsons 1.8sxi in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2009, 17:14
  5. Steering Wheel Play...
    By mdre83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2008, 15:07
https:www.vectra-c.comforumshowthread.php126635-Play-in-front-wheel
