Get in
Press and hold both brake and accelerator pedals to the limit of their respective travels
Turn ignition key to Position 2, ie dash lights on
Release accelerator pedal
Re-depress accelerator pedal to the floor
Turn off ignition
Turn on ignition to position 2
The engine symbol on the dash will then begin to blink
There will be a sequence of flashes, separated by small pauses between numbers and a longer pause between separate fault codes.
The number of flashes needs to be counted and thus the 4 digit fault code can be determined.
EG, if the flash count goes as such
10 flashes
small pause
1 flash
small pause
1 flash
small pause
10 flashes
Longer pause
10 flashes
small pause
1 flash
small pause
10 flashes
small pause
10 flashes
Then there are 2 fault codes recorded and they are
0110 (ie 10,1,1,10 flash sequence)
and
0100 (ie 10,1,10,10 flash sequence)
Hope this helps
read the code first then we can point you in the direction of the hoses
