Thread: cdti engine pic
    Regular Member jofenan's Avatar
    nottingham
    Default cdti engine pic
    i think i have one of the rollers missing off my aux belt (between the bottom pulley and power steering pump?)..does anyone have a pic of the belts on a 2008 cdti 150 bhp please
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    should be like this!
    nottingham
    thanx....the bottom g is missing off mine!!!!!!
    PRESTON
    and the belt is still on?????? i didnt think the tensioner had enough movement in it to take up that amout of slack. If it helps, the part number for that roller is 55190811
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    As above its a guide roller & would have thought the belt would be off!, but maybe your lucky get it done & dont run if poss before changing it.
    Regular Member DaveW555's Avatar
    Cannock
    depends if someone has fitted a shorter belt to compensate for it, if they have then it will probably be ok but if you dont know the history of the motor get a pulley and a new belt
    nottingham
    ok...got the pulley from vauxhall...then the belt wouldnt fit....and i checked with vauxhall and the local factors and it's the right belt....had to get one 3 cm's longer for it to fit???
    the rattle went away for a bit then returned about an hour later....but instead of it being only from tick over to about 1500 rpm its now there on tick over and when the engines under load...ie driving through the gears....you can rev the engine out of gear and there's nothing....its a very metallic sound...almost like a loose heat shield type of noise...but its coming from near the bottom pulley and go's when there's no v belt on...i've got a 7mm shorter v belt to make sure it's not the tensioner hitting itself again.....then i guess the next step is to change the bottom pulley???
    Sodding Typical on Sea
    If the car is an 08 it should be still just about under warranty is it not?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The way to check a crank damper pulley is put a line across it & the sump/block as shown in the link/pic, run the engine stop/start & check the pulley & line match up again, if so its OK if not then according to the damper manufacturer's recommendations its naf!, they say it should stop in the same place EVERY time!.
    http://www.vectra-c.com/forum/showthread.php?t=116222
    nottingham
    well....the pulley definately doesnt stop in the same place as i had to read the part number off the sticker a second time....after a few starts and stops it was at at the bottom and i could read it!
    and it would be under warranty if i wasnt a taxi driver (85k on the clock)...although i had a new engine fitted in jan last year...you only get a year warranty and it was up on the 8th...very annoying
    my local motor factors have to do a special order so i'll be sorting that out tomoz
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. V6 CDTi Engine Oil
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2012, 12:28
  3. Hi, 1.9 CDTi, which engine?
    By Craigus in forum Introduce yourself.
    Last Post: 1st January 2010, 11:09
  4. What is the best engine oil for 1.9 cdti?
    By Nev in forum Engine & Drivetrain
    Last Post: 18th May 2009, 15:21
  5. 1.9 CDTI 150 Engine
    By Gavin in forum Engine & Drivetrain
    Last Post: 30th September 2005, 17:09
