How easy is it to retro fit some front and rear mud flaps to my 54 plate CDTi SRi Estate bearing in mind i am not very mechanically minded
How effective are these mud flaps?
Michael
Michael
It's an easy job mate, I retro fitted them to mine but had to use the flaps from an Astra G as mine has the XP kit fitted.
I found it easier to take the wheels off too, just make sure that you have them lined up correctly if you go down this route. Reason I say that is because after you have the rim off and car jacked up you can't align them
forgot to add, found them very effective too as the skirts were getting chipped because of the rims. Also seem to stop a lot of the spray ending up on the back door window
here you go
thanks for that, are they genuine vx ones? I thought the rear ones were not as big as that?
http://cgi.ebay.co.uk/New-Genuine-VA...item4aa4ebcc04
The normal mudflaps are not that good.. actually think those are better.. ( i have the normal on mine)
ah ok, thanks for your help I appreciate it
