Thread: Replacement Springs Shorter?
    N
    Default Replacement Springs Shorter?
    Hi all,
    Got a vectra C which had a failed its MOT on a broken spring. Ordered the replacement (KYB RX6222) but its shorter than the one I took off? Bit of an issue as I am only replacing one side (as im looking to lower in 3-4months anyway).
    I double checked on the KYB catalogue and it looks like its the correct p/n (2002+ standard suspension for a 1.8 on the rear).
    Is it normal for the spring to be shorter? There are 4 main coils, but the one I took off has 2 smaller coils at either end and the replacement only has 1 smaller coil at each end.
    Really need to know asap as the car is on the driveway missing a spring as I type!
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    the one you ordered may be for a sri what mmodel is your car
    N
    Its SXI but i think its with the standard suspension. Also the broken spring has yellow paint on it which i believe indicates standard setup.
    The replacement I recieved is defo for standard spec, as i have double checked the partnumber on the box and spring itself. Was also told by my motor factor that the SRi springs cost significantly more than what I paid.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    no sxi has sri springs mate
    N
    I dont think so? Only if is was specc'd up to. Think early 2002-2004 vectra SXI's which came with the non-sri bumpers etc all came with standard suspension.
  1. Replacement springs question
    By Chip in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2012, 19:55
  2. Rear Springs Replacement
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 4th November 2012, 20:38
  3. replacement springs 1.9 cdti sri
    By sardean in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 00:19
  4. Need replacement springs for SRi 2.2DTi...
    By Innes in forum Handling & Braking
    Last Post: 7th February 2011, 16:53
  5. front springs replacement
    By mhvcbv in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2007, 14:15
vectra c sri springs shorter
