Results 1 to 10 of 13
Thread: Suspension problem
    Shropshire
    Default Suspension problem
    I've had a clunk on the car for a few weeks - does it for a day or so, then doesn't, usually going over bumps, but not always. Drove to work this morning, then had to move into a different space. Nothing untoward. Got in it tonight, went to pull out of space and an awful grinding noise coming from the front. Got out, had a look, and the front left arch is just off the tyre. No play when pushing down on the bonnet. Thought the clunking was drivers side, but it would appear not. Is it a snapped spring, or shock? Couldn't see anything as it was dark, but will get the AA to tow it to the garage tomorrow. Just hope it's not expensive, as I've had to replace the front bumper, and need to get that sprayed.
    Engine : 1.9 CDTi
    Sounds like snapped spring.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Well and truly snapped by the sounds of it. It sounds like it may be rubbing on the inside of the wheel too
    Shropshire
    Thought so! I've left it at work - it's only 3 miles, but the garage I use is 25, so back of an AA truck tomorrow!
    Cheers fellas.
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    Yer def. snapped!!! sounds like it wound itself down the shockabsorber, if this the case may sure the garage check the "flexible brake hose and the inside tyre wall" as these can be damaged also...
    Shropshire
    Thanks Omega, will do. Only put new tyres on a couple of weeks ago, so don't want any damage to that!
    Shropshire
    Well, it's managed to bend the anti roll bar, and the brake line. The spring was against the tyre, but managed to get it to the garage only moving it around a foot onto the tow trolley, so at least that's ok!
    Engine : 1.9 CDTi
    Shame you didnt check the 'Clunk' out a few weeks ago
    Shropshire
    I know!
    Still, was inevitable! Just glad it went while stationary - wouldn't have liked that at 70mph on a motorway!
    One less thing to worry about now I guess....
    Engine : 1.9 CDTi
    Time for some lowering springs
  1. Suspension problem?
    By tony-1977 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2010, 18:15
  2. possible suspension problem?
    By Big Knox in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 22:22
  3. another rattling suspension problem
    By kalim in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2010, 20:46
  4. Possible Shock/Suspension Problem?
    By Mazzy in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2009, 15:01
  5. HELP! front suspension problem
    By pinoy in forum Suspension, Wheels & Brakes
    Last Post: 25th March 2006, 10:15
