Results 1 to 10 of 14
Thread: Headlight brightness tip
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Lightbulb Headlight brightness tip
    Thought I would share this with you as it has helped improve the dipped beam on my signum, which was diabolical with ordinary bulbs, and still pants even with Osram Nightbreakers.
    For reasons unknown to me, the signum seems to use PWM (pulse width modulation) to regulate the nominal voltage to the bulbs at around 12 volts regardless of the battery voltage. With the engine running the battery voltage is about 14 volts, but the PWM means that the bulbs still only received a nominal 12.4 volts.
    I fitted a large electrolytic capacitor in parallel with each dipped beam bulb using scotchlock connectors - obviously insulating the capacitor leads to prevent shorts! The capacitor helps fill in the gaps in the PWM waveform, resulting in a higher nominal voltage at the bulb.
    I used 10,000uF/25v capacitors as I already had these from a previous electronics project which resulted in a nominal 13.3 volts measured at the bulb and a noticable increase in brightness. Using a higher value capacitor, eg. 20,000uF may give an even higher voltage (up to but not exceeding battery voltage) but then the physical size of the capacitors may become a problem.
    The extra brightness certainly makes a difference in wet/dark conditions, but they are still no where near as good as my old Astra-G!
    Regular Member gibbon7000's Avatar
    lincs
    Or simply upgrade to HID's
    Regular Member Jezzy's Avatar
    S.E
    Are you sure you won't burn out the bulbs quicker than usual? Nightbreakers' extra brightness only lasts about 9 months anyway.
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Hmm, they lasted about a year in the Astra which had nearly 14v at the bulbs so I can't see any problem.
    In any case I'd rather see where I'm going and buy new bulbs every 6 months than have bulbs that last 5 years but not be able to see
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Or disable the "PWM" bye enable Xenon in the UEC...
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by kenp View Post
    Thats a better solution, but how does one do that??
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Quote Originally Posted by littleteapot View Post
    Need to get Tech2 on it
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by keefy*2010 View Post
    Ah, so for those of us who don't have a friend with a Tech2, my option may be signigficantly more cost effective
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Or a legit version of OP-com/Vaux-com can also do it.
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    explain more! what area of this legit software would that be.
  1. rear light brightness not identical
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2012, 10:47
  2. Display Brightness.. Can it be adjusted
    By Sigmacca in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2012, 06:14
  3. Sat Nav brightness
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2010, 20:55
  4. Centre Screen Brightness
    By DeathStar in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2007, 19:23
adjustment pwm bulb voltage vectra c opcom
