Results 1 to 3 of 3
Thread: Struggling to change gear...
    Cambridge
    Engine : 3.0 V6 CDTI
    Default Struggling to change gear...
    Happy New Year all....have a strange issue with my Vec C V6 CDTI, i'm really struggling to change gear, 1st is pretty much a none starter, when starting off in 2nd (if i manage to get it in 2nd) without even lifting my foot off the floor the car is pulling forward, with engine off i can engage all 6 forward gears and reverse without issue. It seems to have started all of a sudden, could this be a thrust bearing/clutch issue? If so what kind of cost am I looking at to repair?
    Thanks in advance for any help...
    Dunc
    Chelmsford
    Sounds like your clutch isn't disengaging when you put the pedal down.
    Most likely to be a clutch master cylinder problem, or a leak in a pipe.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    can you engage gears if you pump pedal 3 or 4 times
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. gear change
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 09:31
  3. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  4. change gear
    By aptoman in forum Engine & Drivetrain
    Last Post: 3rd June 2008, 23:16
  5. Gear box/change
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2007, 23:39
