Thread: Do rear shocks ever rattle?
    Oct 2010
    N. Ireland
    Default Do rear shocks ever rattle?
    I still have my rattle/knocking at rear of car,around wheels. It rattles when on rough roads or small bumps in the road, its fine if the surface is smooth.
    Ive tried pulling the wheel in all directions while car is on ground, no movement. I jacked her up, took off wheels and visually checked the bushes, dont see any major signs of wear. I was wondering if it could be the shocks, would they ever make these sort of sounds while driving on rough roads.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Possibly brake pads... try driving and when it rattles pull the hand brake a little. see if it goes...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    ARB bushes can cause a rattle
    Oct 2010
    N. Ireland
    Is there any way of telling if it is the ARB bushes, I looked at them closely and they dont seem cracked or perished at all.
    I suppose i could always replace them, seeing as there cheap and easy to do.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's worth just replacing them mate, even if they show no signs of wear they can still rattle. As you say they aren't expensive either
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Next time you hear the rattle, gently, and as long are you are not going fast, apply the handbrake, if it is the pads the rattle will go away.
    Oct 2010
    N. Ireland
    Thanks for that mate, i'll try it later, dont like that beeping noise when yo pull on the handbrake whilst moving.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    You could just try pressing gently on the brake pedal then, but by using the handbrake your isolating it down to defiantly the rear brakes. I had a nightmare with mine. I eventually made up small shims to stop my pads rattling.
    Quote Originally Posted by melvin View Post
    Yes, that is what mine was exhibiting for several months before the shock absorber finally gave up the ghost
    Dealership and local mechanic both said no fault found
    The issue didn't become obvious until it started to leak
    Oct 2010
    N. Ireland
    Tried the handbrake trick today and still have the rattle.Goin to replace arb bushes at weekend. Did I read somewhere there is a difference in the size of these 18mm and 19mm?
    Any ideas which ones would be on 56 plate cdti exclusive 150, or will they be able to tell by reg at auto spares?
    If this doesnt cure it I will suspect shocks maybe?
  1. Rattle from rear
    Last Post: 12th April 2012, 08:52
  2. rear shocks
    By apache653 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2011, 08:42
  3. car rattle at the rear
    By jim269 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th October 2010, 16:55
  4. Rattle from rear of Car ?
    By Thunder in forum Suspension, Wheels & Brakes
    Last Post: 26th August 2008, 07:41
  5. Rattle at the rear
    By shippers in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2007, 00:15
