Thread: Rear Centre Brake Lights
    Jul 2010
    Holland
    confused Rear Centre Brake Lights
    Hello,
    does anyone know how to unmount the center brake light?
    in a c1 sedan? I want to mount a smoke light instead of the red light!
    many thx
    eugene
    cambs
    hi
    it should unclip from the inside,
    but some have a shield around it
    and then you will have to pull it out and hope
    Jul 2010
    Warrington / Liverpool
    Mine's got a shield (52 vec hatchback), how do you pull it out? Do you mean pull the shield off or the light unit?
    cambs
    just pull it out from the rear,
    it will brake but if your replacing it,
    then it dont matter
    Dunstable
    I had an awful job getting the old one out of my last veccy, had the sheild round it. Had to do my best at pulling it out but ended up breaking it into bits and getting it out like that. Stupid design really.
    Jul 2010
    Holland
    Quote Originally Posted by Ademusic View Post
    was it easy to install the new one once you breakout the old one? didn't you dammage your car?
    greets
    Oct 2006
    southampton
    16 Post(s)
    the newer models, you have to remove inner tailgate lining to remove it, fiddly and painful on your hands too....
    slough
    Default third brake light removal without damage
    look very closely at the third brake light you will see four metal silver clips at the edge pf the light, cut up a old credit card or i used the spreader out of a tin of p38 car body filler icut the spreader into four peices so that you have four bits all with a taperd edge use the spreader with the tapeder edge down the back of the light between the plastic edge and the paint work of the body work with all four in place the light will pop out good luck......
    slough
    look very closely at the third brake light you will see four metal silver clips at the edge pf the light, cut up a old credit card or i used the spreader out of a tin of p38 car body filler icut the spreader into four peices so that you have four bits all with a taperd edge use the spreader with the tapeder edge down the back of the light between the plastic edge and the paint work of the body work with all four in place the light will pop out good luck......[/QUOTE]
    Jul 2010
    Holland
    Quote Originally Posted by hippo View Post
    [/QUOTE]
    thx guys I will try it as soon as my new one (bougt via ebay) is arrived!
    many thx
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. rear brake lights weird!!!!!!!!!
    By dobby in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:35
  3. rear brake lights
    By jofess in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2007, 23:42
  4. Centre Brake light
    By Karin B in forum Bodywork & Interior
    Last Post: 5th September 2007, 12:41
