Out of curiosity, what other manufacturers wheels will fit my Vec C? Example, VW and Audi wheels............
saab 93?
Mercedes wheels fit these are brabus 20" on Vec-c
saab wheels should fit aswell
Thats the wheels I nearly went for, they go in opposite directions on both sides though ? 20`s now that is cool, it`s the fellow who owned PVD`s car is it Rob ? You need to fit wobbly bolts as the pcd is 2mm off ..Originally Posted by Robward27
Are wobbly bolts entirely safe? and whats the biggest/smallest pcd you can use? Vectra is 110 is it not?
Jay - aren't you in an LS too - is there anything to say we can't fit 19's (think we have soggier suspension than the sri's dont we)
Yep, Merc is 108 which can work with wobbly bolts, you can also go up to 112. I found merc wheels are mostly 9" wide which means you need some big tyres, 245`s !! I think wobbly bolts are safe enough though as I looked into it .
Not a clue about the suspension but yeh ive got an LSOriginally Posted by JCB
Your suspension is softer and higher, if fitting 19`s you would be best to lower it or it would look a bit like a 4x4 ...
What you want is a set of SRi alloys, now where could you get a set of THEM!!! *lol*
