Results 1 to 10 of 14
Thread: What to look for when buying a Vectra C
    Hampshire, UK
    Default What to look for when buying a Vectra C
    Hi All
    I am considering a car change to a Vectra C Estate probably in the 1.9 CDTi 120 version.
    At the moment I think I am likely to find a 55 / 06 reg for my budget hoping for something with around 70k miles if I can.
    What are the common points of failure on these models / common areas of wear and tear that will need doing in time?
    Just want to know where to look and what to listen out for when I get round to looking.
    Thanks in advance
    Tom
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    IMHO the engine is strong. Look/listen for the usual suspension noises and DMF rattle. Should pull strongly. Slightly notchly gearbox but they all do that. Good choice as I think they are a great car. Only downside is that they have a dpf....
    Hampshire, UK
    DPF?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Diesel particle filter mate.
    Jun 2007
    in a white box
    Not a problem really as long as you hit the motorway occasionally.
    Hampshire, UK
    Yeah should hit a motorway for a bit once a week or so.
    Is it worth looking at the 150 model?
    Jun 2007
    in a white box
    Quote Originally Posted by Tom Williams View Post
    I will be shot for saying this......NO
    Hampshire, UK
    Quote Originally Posted by John35 View Post
    Having had a read around I am expecting there are reasons for this.
    preston
    yes dpf is a pain,
    engine is strong but if you buy it, i'd be looking to clean egr, boost and MAF sensor straight away + a routine service
    clutch and DMF are expensive to repair so give it a good test drive, dmf can sound like a bag or spanners at start up
    i'd be checking regular oil changes were done throughout its life
    then at that milage, brakes, although quite cheap to fix and even upgrade
    suspension for broken springs, arb bushes , front strut bearings, generally the whole front suspension
    rear control arms and rear arb bushes
    generally check all fluid levels
    check startup smoke from cold then take it for a drive and see how it goes
    it should feel good between 2 and 4000 revs.
    check any warning lights that stay on
    150 is good if you fancy a manifold change now and again. the gearing of the 120 is better anyway....
    takes your pick, the only thing i'd say is that if you have a DPF its no use using it around town, it will need a regen on schedule to keep it at its best
    Hampshire, UK
    Quote Originally Posted by mparks8590 View Post
    yes dpf is a pain,
    Thanks, thats good information. I have seen a few 150's on the trader however the 120 is more popular.
    I do use motorways and dual carriageways at weekends opposed to weekday use but weekday use does tend to be up to 60mph on national speed limit roads - what sort of use does it need to keep the DPF clear?
    Tom
  1. Buying Another Vectra!!
    By Monkgti in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 13:15
  2. Buying a Vectra
    By Jamesie82 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2012, 00:02
  3. Help Buying used Vectra!
    By Amy85 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2011, 16:27
  4. Vectra Buying help
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 21:22
  5. buying 1.8 vectra 02 need help!!!!!
    By amaughan in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 23:14
